Sponsored by: Auxito
tire size question
Old Jan 17, 2012 | 08:17 AM
nvrlwef's Avatar
nvrlwef
tire size question
Hello I'm new to the forum and just bought a 1998 f-150 lariet. The original owner put 16.5 inch rims on the truck. Stock the truck is rated for 17inch rims. Truck needs tires right away and the tire size is 33x12.50x16.5. My question is will a 16 inch rim fit on the truck with clearing the brakes and rotors? I don't really want to have the extra expense of a 17 inch tire. Also the only tire that I can find in my current size is a bfg A/T. I've heard mix reviews about the tire and its life. Does anyone have advice. Thanks
Old Jan 17, 2012 | 08:25 AM
jthorngate3's Avatar
jthorngate3
I only have experience with the tire. It's a pretty good tire, but can wear a little more quickly if you don't keep em rotated regularly. You'll also get better wear out of a load rated E tire.
Old Jan 17, 2012 | 08:50 AM
92nite351's Avatar
92nite351
16's are fine on ur truck. and a 265/75/16 would look real good and be similar in size compared to the 265/70/17 that came factory. bfgs are ok but truthfully general grabber at2's are better tires with better mileage and traction IMO...
Old Jan 17, 2012 | 09:50 AM
nvrlwef's Avatar
nvrlwef
I wanna stay with a 33 since truck is lifted but that's great to know 16s will fit thanks
Old Jan 17, 2012 | 10:52 AM
92nite351's Avatar
92nite351
you could go 285 70 16.... they r priced better than 33's... would prob look better too.. just a thought.. 285 is very close in height compared to a 33... a little narrower which is good for front end parts
Old Jan 17, 2012 | 11:21 AM
nvrlwef's Avatar
nvrlwef
I will price those yeah i'd like to get new rims and cheaper tires ill have to find a cheap rim with that bolt pattern thanks again
Old Jan 17, 2012 | 11:33 AM
92nite351's Avatar
92nite351
no problem.. there are tons of rims and tires out there, just be sure u gt the back spacing correct. it will save you tons of money in the long run.. these front end parts dont like lifts or any mods to the suspension.. stay as close to stock back spacing as you can.
Old Jan 17, 2012 | 05:21 PM
trsimmons25's Avatar
trsimmons25
16.5's are a thing of the past BFG is the only company that makes one and they are not cheap. All you can do is go 16 or 17 inch and up. If cost is a factor go 16 inch wheels and tires.
Old Jan 18, 2012 | 12:19 AM
whitefordexplorer's Avatar
whitefordexplorer
i work at a shop that sells tires, we have lots of individual brands, the two have been getting the most positive feedback are Achilles and (believe it or not) Firestones...
midsouth
Mar 11, 2013 01:41 PM
ROBBINthaHOOD
Dec 13, 2011 10:58 AM
Hmann
Sep 17, 2009 08:16 PM
duckhacker
May 11, 2004 04:57 PM
onemanchan82
Jun 14, 2003 09:54 AM
