Random Idea, Would This Work?
Old Jan 17, 2012 | 01:55 AM
davewave649's Avatar
davewave649
So i was thinking about the 57-60 bed on my 63. My biggest complaint with it is that the bed is only single wall. Has anyone tried welding in an inner wall to protect the wall from dents from stuff in the bed?
I was thinking of welding in sheets either along the inner lip of the bed then to the bed floor.
Just an idea if anyone has feedback.
-Dave
Old Jan 17, 2012 | 08:22 AM
63' f100's Avatar
63' f100
I think its more effort than its worth. I also think you would have to be very good with metal otherwise it will just look retarded.
Old Jan 17, 2012 | 11:23 AM
Buzz44's Avatar
Buzz44
If I were to do that to my two single wall beds. I would probably go with a removable panel. Weld in or bolt in some sort of L bracket that you could bolt or screw the protective panels to. Put them along the lower side of the upper bed rail and along the bed straigh down from the upper rail. I would make them removable so you could get behind them for clean out so you avoid a rust out situation in place you would no longer be able to reach if you welded them in solid. Just my 2 pennies worth.
Old Jan 17, 2012 | 11:26 AM
OldGrayMare's Avatar
OldGrayMare
If it was me, I would go ahead and put a wood bed in the bottom and sides to match.
davewave649
Thats not a bad idea and would probably make it easier than trying to get large sheets in to weld in place.
Old Jan 17, 2012 | 11:28 AM
davewave649
Ive been thinking about that, the corrugated part of the bed is pretty beat up. Ill keep that in mind
Old Jan 18, 2012 | 07:10 AM
huckdeuceman's Avatar
huckdeuceman
The ''wood floor'' and ''sides'' would look ''SWEET''.....
Old Jan 18, 2012 | 02:51 PM
davewave649
I don't think I'm gonna do wood sides but the floor is still up in the air. I'm thinking I'm gonna go put removeable metal sides when I have the money. As far As the floor goes I'm debating between trying to fix the existing floor which isn't that bad, replacing it with diamond plate and going with a wood floor like what would be in a stepside. But just for the center
FordF350Baby
Paint & Bodywork
Jul 15, 2008 12:34 PM
dgassett
May 17, 2008 02:45 PM
TJDREAMS
Oct 30, 2004 12:53 AM
1990F250LB
Sep 22, 2004 09:58 AM
