If you listen carefully on lift off, the injectors may go quiet which from what I understand is a fuel cutoff, which is when the SG should show the 9999. Basically saying you're getting an infinite mpg due to still rolling and no fuel use. When the injectors start up again the 9999 should change back to realistic numbers. Forgot to check the value, will do later today, sorry!
Probably a general distrust of their accuracy. We use those things around here on hot melt equipment, and have proven that they often give wrong results. Differences in color or cleanliness of the material affect them. Also trying to shoot a temp when the target is not large enough is a problem. Most of them have a target dot of around 2" at the distance you would be from an engine. Even though the laser is just a dot.
They are sometimes okay, but in this case if it didn't match what an OEM sensor was showing within 5 or 10 degrees, I would have zero confidence. You guys may have had better luck than we have.
To be absolutely honest I have virtually no experience with them. I know by my short stint in the appliance parts/repair business they're worthless for freezer/frige and oven temps too. I thought that by shooting the sensor on a 6.0 it would give a fairly decent reading. Interesting information though.
The ECT is close but not exactly the same as fWT in my experience, maybe just reaction time difference, I say try them both and see because you can watch them at the same time. If you feel like it try the +6 version I posted and let me know your numbers please!
Ok will try to make sense of this if possible. Drove about 40 miles.
1. first 5 miles in town really didn't pay much attention .
2. 15 miles interstate 65 mph EOT 204*, fWT 188* constent, ECT 194*-196* this was the mth + 6.
3. 15 miles back with mth normal code. EOT 204*, fWT 188*-190* a few times mainly stayed at 188*. ECT 194*-196* mainly stayed at 196*.
4. 5 miles in town EOT 201* ,fwt 190*-191*, ECT 192*-193*. also mth normal code.
Thanks for the numbers! Looks like the fWT might be off then IMHO, as it says you never got to 190 which is supposed to be the operating temp of the engine from what I've seen posted. So, knowing your truck better than anyone else, does the ECT or the +6 Mth seem right?
I'm no expert on the 6.0 and still hoping for a definitive answer from somebody about the +6 but seems to make some sense.
The PCM reads the voltage return from the ECT sensor and calculates a coolant temperature. It provides this as a PID. Actually, it might provide multiple PIDs, it might provide ECT sensor voltage, temperature in C, temperature in F, etc. I'd have to hook up AE to see specifically what. AE reads the PCM and determines all the available PIDs for you.
Then the SG reads the PID from the PCM. So, why is the SG reading the PID and getting different values? It shouldn't be possible. The only explanation is maybe it's reading ECT probe voltage and trying to do it's own math, and doing it wrong. Or it's reading C and trying to calculate F and doing that wrong. Who knows.
The thing is, it's all coming from the same PCM, so the numbers should be the same. The PCM provides a coolant temp value, already calculated. Any device should read that value and present it to the user and they should all be the same. When they are not, there is obviously a problem.
If the device itself cannot provide the same reading of one value twice, it's either programmed wrong, or the end user programmed something wrong. Either way, I don't see how the device can be trusted as a diagnostic tool.
I'm really not sure I done a coolant flush 3 weeks ago and replaced t-stat with a MC from dealer. Old temp would only get to 179* max. Now 188* with fWT or 190* with ECT I programed tonight. I would assume they would read the same. I'm looking for a defintive answer my self . If the +6 is right oil cooler good , without +6 oil cooler needs replaced. Huge factor.
The two prior posts sum up my dilemma. I bought the SG as a diagnostic tool specifically for the temp deltas. I think it's reading a core value from the PID, that's why there's the MTH section in the xgauge, to convert the core value to a value a human can understand.
I actually got similar values today after pushing the truck in town ECT 204 max, ECT 196 max in 52 ambient temps, no more than a delta of 8, average was about 4. On a cool down idle temps stabilized at EOT 190, ECT 190. That's with the +6 ECT.
So I'm really thinking the +6 might be right, and I'm also in the same boat if it's not, needing a cooler soon.
Plus over the summer without the +6 I showed over a 15 degree delta more than once but never got the CEL on the dash like my latest flash is supposed to set if my delta is out of spec.
I think we really need to find a way to know for sure how to know which MTH is right, but no idea how to go about it. And I don't know anybody with an AE or other tool, don't want to pay my local dealer a diagnostic charge just to find out either!
I'm in the same boat as u. Only my delta is 18*-20* without the +6. I'm going to due another cold soak will check tomorrow evening. I noticed tonight when I went to start truck my fWT was showing 34* and EOT 38*,TFT 34*. Truck had been setting since Saturday. Sunday night when I checked temps there was 1*- 1 1/2* degree diff. between fWT , EOT. IDK?
Follow me on this,
So, during the day, when your all your temps are going up outside your fluids follow, then as the temps start going down the same will happen. So Last night you get in the truck, the temps are coming down and the ECT 34 EOT 38, High for the day was what, around 45? Oil will cool slower than coolant. So, at some point in the mornings, both will be about the same I would bet. That would be during the hour when the temp outside starts to warm back up.
So when you check tomorrow night, you will get the same thing, ECT will be lower than the EOT. By how much? not sure, your temp change on wednesday night is less than tonight, 24th as compared to 25th. Your high for the day is supposed to be 38 ,25th, and low to 30, so I'd say around 4 pm your temps should be about the closest you will see.
ALL the Xgauges values in a Scan Gauge II can be manipulated by the math section of the formula. I'm sure that the Dash Daq and AE use a very similar method and that even the PCM's of our trucks use some sort of math formula to translate the electrical signal to a digital reading. We've actually run into this "problem" before by manipulating the signal from the MAP, EBP and Barometric sensors to compensate for differences in altitude. These all assume that the sensor is reporting the information correctly to start with. IIRC we even had two different PID's to read IAT2/MAT that reported the same temps but responded at different rates. I never did get a complete explanation for that. At any rate, without knowing what PID Linear Logic uses to program fWt vs. the PID that we plug in for ECT vs. the PID that the PCM uses, how do we really know what is correct?
Just so you know, this time of year, according to SGII and the Torque APP, my EOT never breaks 197.
I can get ECT to get to 194 but not very often. Also, the fan is running to help keep the ECT In check. At 192 this morning, fan speed was around 565 rpms. When I was coasting the temp dropped to 188 and the fan dropped to around 450, then at idle dropped to near 300.
One more time from the beginning. After an all night cold soak the numbers should be the same. That is where it will tell you if the math is correct. Once the engine is running the temps will, and should, chase each other depending on conditions. Let's not turn this into rocket science math.
