Sponsored by: Real Truck
strange valve
Old Apr 20, 2003 | 12:07 AM
03F350SD's Avatar
03F350SD
Question strange valve
I have a 03 F350 SD. I was looking under the hood a saw a strange valve in my line that goes to the heater core. What is ? How does it work? Is It good to have it on my new SD? I hope some one out there knows what this thing is?
John
Old Apr 20, 2003 | 12:26 AM
usmccowboy's Avatar
usmccowboy
strange valve
ive heard of some guys putting in a valve to shut off the coolant going to the heater core to make the a/c colder. i dont think that it is needed because the a/c already spits out ice cubes but i guess that it would work. my a/c is cold enough even for texas
Old Apr 20, 2003 | 07:11 PM
nafzimo's Avatar
nafzimo
strange valve
Originally posted by usmccowboy
ive heard of some guys putting in a valve to shut off the coolant going to the heater core to make the a/c colder...
With a '03, I don't think that is the case. Do you have a pic of this valve?
Old Apr 20, 2003 | 08:06 PM
03F350SD's Avatar
03F350SD
strange valve
It looks like it, but doesn't act like it.
Old Apr 20, 2003 | 10:30 PM
Shepard's Avatar
Shepard
It says the valve is for the powerstroke, but I can't think of any reason why it would not work on a V-10. Anyone else?
Will it allow flow through the heater core in all other modes?
If so, what exactly is it doing so that it only works in MAX mode?
My a/c does not cool my cab and it has been checked out several times by the dealer.
Old Apr 20, 2003 | 10:43 PM
03F350SD's Avatar
03F350SD
strange valve
The news that I am getting is that with that valve in the heater core line. On Max A/C it shuts off the coolant flow to the heater core. On the max a/c you can go fromcold to hot, with no change it the air temp from the vents. I have this on my 03 SD. But the temp still works. It will get hot, on the hot setting. I talked to the dealership, they said that in works the way it's suppose to. But this mod shuts down coolant in the max a/c setting. It is the same thing. Why does ford's valve act different? Some one must know the answer. I hope I could get my point across.
John
Old Apr 29, 2003 | 11:34 AM
Shepard's Avatar
Shepard
strange valve
I'm knocking this back to the top since the last two posts had questions that have gone unanswered. (and I had one of them! )
Can anyone help out?
Old Apr 29, 2003 | 08:08 PM
run8's Avatar
run8
strange valve
I just added the heater core shutoff to my 2000 gasser... it works just fine, although I need a hot day to see if the AC is noticably cooler.
-IKE
Headviking
6.4L Power Stroke Diesel
Oct 17, 2014 10:35 AM
Jojiggler
Mar 24, 2008 11:43 AM
6.0 MO
Jul 11, 2007 05:52 PM
03F350SD
Aftermarket Products
Apr 16, 2003 11:08 PM
TKONO
Mar 25, 2002 08:13 AM
