Having Trouble with Points
Old Jan 22, 2012 | 02:16 PM
oldbumpinford's Avatar
oldbumpinford
thanks for all the feedback!! would the fact that the key was keft on for a couple hours ruin anything besides the points? also we did check the coil and it works fine and it has relatively new plugs and wires
Old Jan 22, 2012 | 02:59 PM
tmcalavy's Avatar
tmcalavy
Could also affect the condensor...always change points/condensor as a set, like a pair of shoes.
Old Jan 22, 2012 | 03:49 PM
RKDxpress's Avatar
RKDxpress
Too hot of a coil can burn up points quick. So stay with a stock coil. The guys are right pertronics work great. But from your issue of misalighnment I think the dist is lose in its seat (poor gasket or holddown an bolt) or dist shaft is wandering (poor bushings or worn shaft). Hand check for wiggles, then check your timing and watch if the mark wanders a few degrees or stays solid on the mark. Last of all watch out for cheaply made points sets that can wander on thier own. I've run points for decades still do but you can't beat modern tech.
Old Jan 22, 2012 | 06:34 PM
oldbumpinford
i know the dist. isnt worn out cause its brand new and its keeping in time so im goin to try changing the condensor
Wolfman John 2
Jun 22, 2018 03:23 PM
yardape1
Oct 12, 2016 03:16 PM
hallgren87idi
Nov 24, 2013 11:22 AM
Killroy
Jan 28, 2011 09:02 PM
Earl
15
Jan 18, 2010 04:28 PM
