Scanguage Freezing
Old Jan 16, 2012 | 12:17 PM
BobbyB's Avatar
BobbyB
Scanguage Freezing
My Scanguage will occasionally stop updating. The only way to get it to work again is to, turn off the truck and re-start it. Unplugging and replugging the unit does not work. Have any of you guys experienced this?
Old Jan 16, 2012 | 12:40 PM
BLADE35's Avatar
BLADE35
Seems like mine will freeze up if I try and turn it on B4 the truck turns it on
have you tried to reset the SGII yet
Old Jan 16, 2012 | 06:51 PM
BobbyB's Avatar
BobbyB
Hey Benny, no I haven't tried to reset. I think that I will loose my x-guages. Do you know if thats true?
Thanks!
Old Jan 16, 2012 | 06:56 PM
BLADE35's Avatar
BLADE35
Thanks!
No you wont lose your Xgauges
But you will lose your Fuel econmy stuff and I think you might have to program what truck your running on it again
But the x gauges will stay
Old Jan 16, 2012 | 07:18 PM
tonefordays's Avatar
tonefordays
Have you tried slowing down the Update Rate? The manual says something that if you have the update rate too high, it may run irregular. When I had mine set to "Fast" it would freeze, or not even show readings.
Just a thought.
Old Jan 17, 2012 | 12:04 PM
BobbyB's Avatar
BobbyB
Good point, I'll try that if it freezes again.
mxer0022
6.7L Power Stroke Diesel
Jun 19, 2019 10:50 AM
NHNRS
2014+ Transit
13
Sep 22, 2016 10:12 AM
corbin9191
6.4L Power Stroke Diesel
Feb 14, 2013 03:54 PM
6.9 diesel nut
17
Sep 7, 2012 01:11 PM
2cylguy
Jan 11, 2010 11:59 PM
