Broken driveshaft
Old 01-16-2012, 08:29 PM
piratius's Avatar
piratius
piratius is offline
Originally Posted by Deluxetruck
I believe these joints were a 1310/1330 conversion joint, with the axle side being the 1330. Keep in mind that your new shaft does not need to be that way. If the wider end of the joint is on the axle, you can search out a shaft with normal 1330 size joint, or "square" as you put it, and not have to deal with the conversion joint. Either option is fine.
Had this on my old Wrangler. The driveshaft was a beefy unit originally intended for a vehicle with an upgraded axle - my axle was a stock 1310 series, so the u-joint was "rectangular" (1310/1330 conversion).
It's just a lot harder to track down the parts if you get stuck somewhere compared to a "square" u-joint (straight up 1330 or 1350) which you can find almost anywhere.
~brad
Alex Bindas
03-16-2014 04:23 PM
94 ranger tyson
1983 - 2012 Ranger & B-Series
01-19-2010 09:17 PM
93FordCTD
Offroad & 4x4
01-11-2010 11:46 PM
Kuskoal
11-01-2008 09:29 PM
redteamgo2000
10-28-2008 10:53 PM
Quick Reply: Broken driveshaft
