Need help with Rebuilt AOD
Old Jan 15, 2012 | 11:38 PM
dsc's Avatar
dsc
I rebuilt My 1989 F150's AOD transmission, used Bad Shoe Rebuild videos. Engine is a 302. With 1500 stall converter and recommended upgrades per video
History.
• After rebuilding and installing back in truck I experienced reverse only no forward gears.
• Traced Problem to bad valve body. I replaced with rebuilt valve body and all gears returned.
• Checked alignment of TV cable per video.
• Full with Fluid
Symptom now
• Transmission will not engage unless tack reads 2K
• When hitting 2K it hits it engages.
• Trans does not slip after engages.
• Transmission shifts up/down and into Overdrive normally got up to 75mph no problems.
• Come to stop light, depress accelerator and transmission will not engage until 2k and all is normal after engagement.
Any recommendations for me to check?
Thanks Art
Old Jan 16, 2012 | 10:48 AM
jk080's Avatar
jk080
Transmission Rebuilder
Line pressure gauge will help figure out where the problem is.
Is the a filter gasket and seal on the filter?
Old Jan 16, 2012 | 12:14 PM
dsc's Avatar
dsc
JK80
Yes little square gasket and round rubber one.
Yes I agree need pressure readings I will get asap! Will be able to tell a lot more.
I figured this might jog someones memory as to possibility what the problem might be.
Thanks
Art
Old Jan 18, 2012 | 06:43 AM
dsc's Avatar
dsc
I got side tracked and could not get readings. I will take the checks on Saturday.
I was talking to some mechanics and they say it might be that I have a 2600 stall converter, I don't think so. Can someone clarify, with a stall converter the truck should move forward when I put it into gear. It will not move at all until the tach hit 2k. Rev works fine.
Old Jan 18, 2012 | 07:01 AM
jk080's Avatar
jk080
Your first post you said is was a 1500 stall, a 2600 stall will make it feel like it is slipping. Why do you need such a high stall?
Old Jan 18, 2012 | 07:19 AM
dsc's Avatar
dsc
I think I maybe wrong I called PATCO and spoke to the tech. He said It can't be the torque converter if reverse works fine. I may have something else wrong. Pressure readings will shed more light on the issue. So I guess I need to get the readings! Thanks again for your response!
Old Jan 18, 2012 | 07:25 AM
dsc's Avatar
dsc
Sorry Typo 1500 stall converter
Old Jan 21, 2012 | 10:15 AM
dsc's Avatar
dsc
jk080. GUESS What!! FIXED!!!
Ok . The TV pressure was way off, Tested with Guage in TV pressure port
now readings:
1. Before=Idle in Neutral, Brake on = 0PSI
After=Idle in Neutral, Brake on = 4 lbsPSI
2. Before =Idle in Neutral, Brake on and .404 spacer = less than 10lbs PSI
After =Idle in Neutral, Brake on and .404 spacer Test (made mine!) 35 PSI
Road test = all Foward gears no hesitation, Shifting Perfect!!
Anyone not adjusting the TV pressure or checking it is making a big mistake. I was ready to pull out AOD and pull apart!!!!
vicp21
29
Jun 3, 2018 06:33 PM
nastruk95
Jul 30, 2015 11:25 AM
fgcox1
Mar 17, 2015 08:24 PM
whateg01
Jan 21, 2007 09:06 PM
88bronc
Jan 13, 2003 09:33 PM
