Another Exhaust Manifold Question
all right guys im still putting off this job and i have a few more questions. i dont have the money for the hedman headers right now so i have to put the logs back on. besides making sure that mating surfaces are flat and there are no cracks what else do i look for? i know i need new gaskets but what other parts? should i get the new studs from ford? antiseize them? any other tips would be appreciated!
if you cant afford hedman,, try these 99-04 FORD SUPER DUTY F350 6.8L V10 2WD EXHAUST HEADER | eBay
i bought a set.. and yes they say they only fit 2wd.. but i have a 2000 v10 4wd f250.. and they bolted right up and i love them.
but if money is still an issue.. yes get new gaskets and unless the studs are rusted out.. just antiseize them
i would have used the bolts but i had a set of locking header bolts that i used instead.. and ive had no problems with them at all... which is surprising...ive always had header bolts loosen at some point on other vehicles... but these have stayed tight
Try summit racing.
Look up
Dorman 03411 Set of 10
There is also Dorman 03131 and 03129. Sets of 4. Not sure if these will work or not but they appear to be a better quality. I cant find an ARP exhaust stud for that application
Look up
