i am trying to troubleshoot a window issue. need schematic for window switches and also the 4 wiring plugs under the brake booster ? anyone have this? post or email to flg122077@gmail.com
Sorry I didn't understand that part. The four plugs are a multitude of systems and are in many system areas. I can give you the colors or male and female sides of the plugs but to say where the wires go Some are for trailer wiring, some are for power delay, some are for others. Do you want just what is related to power windows?
None of those really are directly related to windows. All four of those plugs are engine and trans controls, overhead console, trailer wiring, courtesy lamps, grounds, and misc. other stuff. If you want those diagrams I need to have a system or it will be worthless to you. It is just colors of wires and the plugs which I am sure you already can see.
Any idea which plug the rogue wire reached to? That will help.My guess is trailer wiring but not sure as to why. There should be a shiny spot in the wire it came off of that is very small at minimum. Hopefully it only reaches far enough to one of the plugs, that would really help in finding where it should go. I am 99 percent sure it is unrelated to your window problem.
there were two wires going to + of the battery. they both traveled to the same are. one is scotch locked to a wire and there is another wire in the bundle that looks like there was a scotch lock on it. cause it is cut all the way around. showing exposed wire. i will snap a pic and send it over. been a crazy week at work and i get home when its dark out. i will be working on this issue this weekend again. the pass window is one of the last issues i need to fix. That and my door ajar light. i have cleaned and sprayed so much wd 40 in there. i need to figure out with door pin is bad and just replace it. i want to have my dome light back on when i open the doors.
