Sponsored by: Kumho
3" trailmaster 99 mazda b4000
Old Apr 19, 2003 | 07:19 PM
Bulldog2k3's Avatar
Bulldog2k3
hey, i just bought a 3" trailmaster body lift for my mazda truck, im pretty much new to the offroad upgrades, i know for the most part what im doing, but does anyone have any tips before i get started? i dont think ill be able to do anything till tuesday...
and, what size tires can i go on a mazda b4000 with a 3" lift, its got the stock 31" now...
and when i go to order shocks, and they ask for make and model, does it matter that my truck is lifted?
and how do i take my front bumper off?
appreciate it in advance....
the bulldog
99 Mazda B4000
Flowmaster cat back
K&N drop in replacement
Westin Safari Bar
3" trailmaster Lift (yet to be installed..)
Old Apr 20, 2003 | 05:26 AM
Bulldog2k3's Avatar
Bulldog2k3
up
Old Apr 20, 2003 | 01:13 PM
WhëëlMå1's Avatar
WhëëlMå1
w w w . truckstuffandmore.com/tirefitment.htm It appears that you can fit 32-33" (based on ranger specs, couldnt seem to find anything on Mazda). Have you checked Trailmasters site for any specs related to your question? Air tools make installation much easier (I wouldnt tackle one without them). It also helps to identify what everything is in your lift, and lay them out, mock the installation basically. As for shocks, do you plan on purchasing Trailmaster shocks? Yes, it does matter that your truck is lifted. You will need longer shocks with altered damping for your app. I dont know what your bumper exactly looks like, but normally its only a couple of bolts holding it to the frame or crumple zone. You have to disconnect any sort of sensors (and I would unhook the battery before you do any of this incase you setoff that expensive airbag).
Rich
Old Apr 20, 2003 | 01:18 PM
WhëëlMå1's Avatar
WhëëlMå1
Exclamation 3" trailmaster 99 mazda b4000
Guess I neglected to see that you bought a 'body lift'. I thought it was a suspension lift. You do realize that you are probably going to have to alter the fan shroud, adjust some cables, brake lines, possibly alter or bend you manual 4x4 shifter (if equipped), and a few other things? As for shocks, no. You would only need longer shocks if your suspension is altered. That body lift will not give you any more ground clearance. It only allows for larger tires. What I said before about the bumper should still hold true.
Rich
Old Apr 20, 2003 | 03:09 PM
Bulldog2k3's Avatar
Bulldog2k3
im actually not worried about frame ground clearance, its always my doorsills and bumpers that scrape the ground when im wheelin.... its electronic 4x4 shifter, and automatic transmission... the fan shroud, is this a major mod? or will it just take some cutting?
Old Apr 20, 2003 | 03:12 PM
Bulldog2k3's Avatar
Bulldog2k3
i allready laid everything out and got familiar with the kit...
Old Apr 20, 2003 | 03:13 PM
Bulldog2k3's Avatar
Bulldog2k3
all i have to do really is undo all these clips that the tight wires under the hood are connected to, take off the bumpers, take off the bedcover and liner and ill be set to install..
Old Apr 20, 2003 | 03:36 PM
WhëëlMå1's Avatar
WhëëlMå1
I dont know how the shroud has to be altered, if at all, on the ranger/mazda. You might want to post to the ranger forum. I dont know much about them. Someone there has probably installed a body lift.
Rich
Briarcreekrat
Offroad & 4x4
Feb 4, 2012 09:03 AM
marioc956
Offroad & 4x4
Nov 1, 2006 07:15 PM
MSRanger
1983 - 2012 Ranger & B-Series
Jun 22, 2005 06:19 AM
mazdaboy873
Jan 19, 2004 07:16 PM
Bulldog2k3
Apr 24, 2003 07:21 AM
