no start condition (scope graph)
Old Jan 22, 2012 | 02:03 PM
rla2005's Avatar
rla2005
Your DVM values for the PIP sound good. The difference in values from manually grounding and the letting the PIP do it's job are significant. You have a path to follow, IMHO.
Old Jan 22, 2012 | 02:06 PM
rla2005's Avatar
rla2005
Double post....
maro0078's Avatar
maro0078
I am on good way, but don't know where to go now..
What else could have so strong influence to TFI grounding quality ? does PCM so ?
Old Feb 26, 2012 | 02:21 PM
maro0078's Avatar
maro0078
now, my engine is started. Idle is ok, but when try to rev, looks like come cylinders are not working:
IMG 02691 - YouTube
slow throttle - revs up, fast throttle to wot - starts to shake...
pressures are all between 115 and 125 psi. Changed almost all parts: spark plugs, injectors, dizzy, TPS, spark plug cables....
No power under load, what to look now at ?
Old Feb 26, 2012 | 02:47 PM
Blue Rebel's Avatar
Blue Rebel
Sounds like you have a missfire, double and triple check your spark plug wire routing make sure you have the wires routed to the correct cylinders.
Old Feb 26, 2012 | 02:53 PM
maro0078's Avatar
maro0078
they are sure correct. Misfires are present only when I fast open throttle, when very slowly - no misfires.
Old Feb 27, 2012 | 12:07 AM
rla2005's Avatar
rla2005
Fuel pressure?
Old Feb 27, 2012 | 12:47 AM
maro0078's Avatar
maro0078
40-45 psi, I have a gauge on the dashboard.
Old Feb 27, 2012 | 09:43 AM
rla2005's Avatar
rla2005
Should be in the 30-38 psi range with the engine running at idle and the vacuum hose connected. 40-45 PSI with the vacuum hose disconnected or with the Key On/Engine Off.
Did you ever go back and check the grounds at the engine block, passenger side fender and on the radiator support?
Blue Rebel mentioned plug wires and routing. It is just as important to make sure the wires are routed correctly as well as on the correct plugs.
Use this for reference to prevent cross-fire: Spark Plug Wire Routing for '94-up 5.0L & all 5.8L
Old Feb 27, 2012 | 01:44 PM
maro0078's Avatar
maro0078
Thanks for tip, I will check the cables routing.
Question is, why during slow free acceleration engine rev up normally, but at fast open of throttle it starts to shake and misfiring.
Old Feb 27, 2012 | 02:17 PM
rla2005's Avatar
rla2005
Hard to say. When snapping the throttle open does the fuel pressure increase or decrease? It should increase.
crucialprospect
Jun 24, 2016 03:21 PM
Walston
Jul 11, 2010 06:36 AM
cfrives3
1978 - 1996 Big Bronco
25
Mar 18, 2008 08:45 PM
pmipmatt73
31
Jul 23, 2007 02:04 PM
Gov
Jan 17, 2005 04:28 PM
