Offy--C or DP
Old Jan 14, 2012 | 09:11 AM
minnesota-clint's Avatar
minnesota-clint
Offy--C or DP
I'm looking to try trade my new hedman header for a aftermarket intake (going with efi manifolds), so if I get lucky and can choose, would I want the Offy C or DP and is there any difference with the other aftermarket intakes out there? My engine is a stock reseal/build and am going to convert to the durasparkII ignition. The truck will be used for delivering firewood, but also will probably be used as a daily driver so my "honey" can drive the car to work.
Old Jan 14, 2012 | 10:57 AM
Harte3's Avatar
Harte3
Clifford is the only other aftermarket intake currently available and it is like the Offy C. The DP is a 4v carb only intake. The C is versatile in that a 2v or 4v carb can be used. Some use a 4 hole spacer on the C to improve low speed throttle response. The choice is yours.
Old Jan 14, 2012 | 12:19 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I like the C on my truck but if someone will make a trade with you just take what you can get - either way it will be a big upgrade over the factory 1-bbl.
Old Jan 15, 2012 | 10:00 PM
F-250 restorer's Avatar
F-250 restorer
You may have to grind on the efi's a bit to make them fit with the new intake. You'll also need (unless you get the late model Clifford with the water fittings in it) a heating plate.
The swap is easier with studs.
Old Jan 16, 2012 | 03:07 PM
minnesota-clint
If I can't find a trade for a aftermarket intake soon enough and decide to bolt up the 1v, is there anything to be done at low or no cost to help with that temporary setup.
Old Jan 16, 2012 | 03:55 PM
rustywheel68's Avatar
rustywheel68
there are adaptors that will let you bolt a 2bbl carb to the 1bbl manifold.
Old Jan 16, 2012 | 04:08 PM
minnesota-clint
Thanks, I didn't know that. I've got a 2v off a Ranger sittin round doing nothing, guess I can do the duraspark II swap now without having to buy a carb.
stealth1
52
Jul 14, 2015 05:59 PM
Samsn4
WTB - Parts & other
Nov 5, 2012 11:12 PM
arcaidy
Mar 7, 2011 08:24 PM
Black_Stallion
30
Jun 1, 2010 10:07 AM
steve83
Nov 28, 2002 02:51 PM
