well its been four years the last time my flattie ran.
got it going last nite, it was only running on 6 cyl.
did a quick comp test and i got 2 dead cylinders, side by side.
going to pull off the intake tonite to see if i got stuck valves. i hope that is all it is.
if not it is off with it,s head or one at least.
wish me luck
JMO, but I don't know that I would start tearing into it right away. If it ran good prior to the long term storage I think I would consider a bit of solvent and soaking the cylinders that are problematic.........Feed a bit of Seafoam or similar while it is running. But that is just me. Yeah, I know, sometimes it is fun just to tear into something. Good luck.
I think pulling the intake will let you get at the stuck valves and apply penetrant exactly where it's needed. You'll also be able to tell if water leaked somewhere.
well got intake off last nite, it was the valve lifters, three to be exact.
some oil and some love taps and they were free.
I think it was just condencation form sitting so long.it should be running today if all goes well.
