Coolant leak
Old Jan 13, 2012 | 01:11 PM
almonyspm1's Avatar
almonyspm1
Coolant leak
I have a pretty bad coolant leak but I'm not too sure where it's coming from. I was driving and saw smoke rolling from under my hood but it wasn't overheating. I finally made it to my gfs and let it sit and idle and was checking under the hood. There is coolant everywhere on the left side of the engine (pass. Side) but still wasn't overheating at idle. I'm going to go check it out a little more in the daylight but if anyone has any ideas to where it might be coming from it would help me pinpoint it. Thanks
Old Jan 13, 2012 | 01:19 PM
fosgate forever's Avatar
fosgate forever
Check the freeze plugs, pretty common thing to rot out.
Old Jan 13, 2012 | 01:35 PM
lew52's Avatar
lew52
Put a pressure tester on it , the heater hoses are in that area....Lew
Old Jan 13, 2012 | 05:33 PM
almonyspm1's Avatar
almonyspm1
I found the leak. It was a small hose under the throttle body. Is this a return line or something?
Old Jan 13, 2012 | 06:23 PM
Ole' gray's Avatar
Ole' gray
what engine model?
Encho's Avatar
Encho
The Southernmost Mod
No, it's probably the throttle heater line, used to heat it so it doesn't get stuck when it's too cold.
Old Jan 13, 2012 | 06:29 PM
lew52's Avatar
lew52
It heats the TB , if its just the hose replace it , if its the TB leaking just remove the hose and plug it...
Kdawg89
Dec 19, 2021 09:01 AM
DeeJayWoody
Nov 29, 2013 08:50 PM
p.ward7885
1978 - 1996 Big Bronco
Jul 28, 2013 07:44 PM
will-work -for-mud
1997 - 2003 F150
Apr 12, 2004 12:34 PM
puremuir
Oct 25, 2003 11:47 PM
