Brake problem again!
Old Jan 18, 2012 | 06:48 PM
  #46
dougbrown's Avatar
dougbrown
Found a 2003 7.3 cc 4x4 I'm temped to go look at if I cant figure this out.
Old Jan 18, 2012 | 08:13 PM
  #47
oldbird1965's Avatar
oldbird1965
Maybe this has been mentioned before but the insides of the brake lines can deteriorate and cause blockage of brake fluid flow. Did you replace them?
Old Jan 18, 2012 | 08:28 PM
  #48
dougbrown's Avatar
dougbrown
No I didn't but looked them over very well.
Old Jan 18, 2012 | 09:12 PM
  #49
Brown Falcon's Avatar
Brown Falcon
Originally Posted by dougbrown
Brown does the unit come with the pin that push on the MC?
As far as I know yes... I havn't done the swap yet myself. I just researched it and found the part numbers. It's supposed to come with the rod for the brake pedal.
Old Jan 18, 2012 | 09:13 PM
  #50
dougbrown's Avatar
dougbrown
Thanks man.
Old Jan 18, 2012 | 09:19 PM
  #51
oldbird1965
I've heard a lot of conplains that the rod doesn't come with it. Guys were making their own.
Old Jan 18, 2012 | 09:33 PM
  #52
Brown Falcon
It depends on where you order it Glenn. The guy I talked to at autozone said it came with it... I couldn't look at the actual unit because they have to order it, not kept in stock.
Old Jan 20, 2012 | 10:00 PM
  #53
dougbrown's Avatar
dougbrown
Brown I don't think the auto zone one come with it. I order mine tonight, should be here tomorrow. It remaned and hope it good, Also got a new MC I have to pick up tomorrow, going to take it apart and clean it before I try it.
Old Jan 21, 2012 | 05:16 PM
  #54
Brown Falcon
Well I hope it works for you. Did you get another stock MC or did you get the bigger F-superduty one that went with the hydroboost?
Old Jan 21, 2012 | 05:23 PM
  #55
dougbrown's Avatar
dougbrown
Nope I just got the stock one and going to mod it. I should have dome answers tomorrow.
Old Jan 21, 2012 | 05:42 PM
  #56
FARM69's Avatar
FARM69
So it's pulling 45 lbs of vac at idle? Why so high?
Old Jan 21, 2012 | 07:36 PM
  #57
madpogue's Avatar
madpogue
45 kilopascals (kPa), maybe? Atmospheric pressure is 15-ish psi, so even if it's measured absolutely (as psi below atmospheric), it can't possibly be more than 15. Even in inches Hg, absolute vacuum is only 29.something. According to this chart: Vacuum Pressure - Converting Units , 45 kPa is about 13 in Hg, which is below spec of 17-21.
Old Jan 21, 2012 | 08:18 PM
  #58
dougbrown's Avatar
dougbrown
I'll take a picture of the gauge tomorrow. Says vacuum psi.
Old Jan 22, 2012 | 12:27 PM
  #59
dougbrown's Avatar
dougbrown
Ok so I put another new mc in it day and still has a soft pedal. I'm going to try driving it and see how she stops. I was wrong on vacuum. It floats between 15 and 18 psi. When I pump the brakes I can pump it down to about 5. Should this happen? When I get home I will post up a vid and pics.
Old Jan 22, 2012 | 02:26 PM
  #60
tjc transport's Avatar
tjc transport
i ain't rite
nope. vacuum should stay at least 17 inches, preferably over 19 inches.
