Brake problem again!
Old Jan 16, 2012 | 05:34 PM
91 Dually's Avatar
91 Dually
Have you adjusted the rear brake shoes up by jacking the truck up with the drums and wheels on the truck? Roll wheel, adjust shoes up with spoon through back of dust cover till u feel slight resistance. Then bleed,,
Old Jan 16, 2012 | 05:53 PM
dougbrown's Avatar
dougbrown
Yes the MC was bench bleed. I will check the rear brakes again and rebleed. Also going to check that vaccum and see what it pulling. Should be about 20 psi at idle right. Lastly I picked up a new master cylinder not a remaned. Will see how it goes tomorrow or Wednesday.
Old Jan 16, 2012 | 06:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
yes, vacuum should be at least 18 inches. lack of vacuum will give you a hard pedal though, not a soft pedal.
Old Jan 16, 2012 | 06:03 PM
WALJON's Avatar
WALJON
Can you pump the pedal when it is running and get brakes or is there nothing?
Old Jan 16, 2012 | 06:24 PM
dougbrown's Avatar
dougbrown
I can pump and will get hard but the will go soft. What thinking.
Old Jan 16, 2012 | 08:14 PM
oldbird1965's Avatar
oldbird1965
Cody, rubber duck, talked about a vaccum booster that would not bleed off. PM him, I can't remember what's it called. I had this problem once but after driving it and bleeding it several times it finally quit.
Old Jan 16, 2012 | 08:31 PM
dougbrown's Avatar
dougbrown
Glenn I tryed to but it wouldn't let me!
Old Jan 16, 2012 | 08:46 PM
oldbird1965
You mean you tried to PM Cody and it wouldn't let you?? I think the boosters name had a 'zero' in it. I'll try to PM him if you want.
Old Jan 16, 2012 | 08:49 PM
dougbrown's Avatar
dougbrown
Yes Glenn I tryed to pm hima dnit say he not receiving messages. I beleive what your tallking about it the zero lose booster. Came in the 96 and 97.
Old Jan 16, 2012 | 09:03 PM
oldbird1965
Ya, that's awful strange. I bet you could PM Travis and he would know how to get ahold of him. I think you got the name right. At the time I was tempted to try it.
Old Jan 16, 2012 | 09:29 PM
91 Dually's Avatar
91 Dually
F5TZ-2005-CA It's called a zero loss booster........ I bought this for mine. Didn't fix it. I finally have pretty good brakes, but still pedal will fall if i sit and hold foot on it.
Old Jan 17, 2012 | 04:24 AM
tjc transport
i ain't rite
i think you have a bad master cylinder Doug.
i had to put 4 of them on the 88 before i found a good one.
remans are crap any more because quality control is in the toilet.
they do not do a very good job flushing the units after boring the piston hole, and there is all kinds of crap left in the hole. so when they put the piston in and you try to bleed it the piston seals get tore up almost instantly letting the fluid bypass the piston.
Old Jan 17, 2012 | 02:06 PM
  #28
Brown Falcon's Avatar
Brown Falcon
You could convert to hydroboost, get rid of the vacuum brakes all together... just a thought.
Getting reman parts from Autozone it would cost you about $250 for the hydro unit, steering pump (if you wanted the one with 2 return hoses), and the two pressure lines.
Old Jan 17, 2012 | 05:52 PM
  #29
WALJON's Avatar
WALJON
I think that you either still have air in the system or like just mentioned you have a bad MC .
Old Jan 17, 2012 | 07:50 PM
  #30
dougbrown's Avatar
dougbrown
So I pulled a vacuum test today 45psi at an idle on the line to the cab control. Brand new master cylinder and still the pedal goes to the floor. I cap the master cylinder and the pedal was rock hard. So I add just front brakes and the pedal when to the floor again. The rear was still caped. This is what I have so far still working.
