Clogged Throttle Body
Old Apr 19, 2003 | 02:05 PM
EJEther's Avatar
EJEther
EGR are pretty common to go out on this truck.
I have an 88 351 that had pretty much what you are describing but it turned out the problem was carbon buildup on the throttle body. I went through lots of stuff before I took it to the shop. Its pretty easy to have a look. and clean it out.
Also I had a leaky seal betweent eh egr and the EGR position sensor. Its just a simple o-ring. You can hook up a vacuum pump to the back of the EGR to test it.
Good Luck
Old Apr 19, 2003 | 02:06 PM
EJEther's Avatar
EJEther
Whoops. I hit new thread instead of reply. Sorry folk
Old Apr 19, 2003 | 07:34 PM
MustangGT221's Avatar
MustangGT221
Reported to admin for deletion.
