Transmission for a 390FE motor?
The BW units were fairly strong according to other posts here. They were a 3 speed + an OD.
The toploader unit is a 4 speed OD trans, incorrectly termed "3 + OD". According to the Kees site, the gears are cut thinner in them than in the performance 4 speeds. Also, there are aluminum cased versions with top and rail shifters, and iron cased units with side mounted shifters.
Someone here was gently running an iron unit behind a 390 iirc....
But what fun is that? You go to all the trouble building a rig like this and you gotta sweat every time you bring the tach over 1300rpm with the clutch in? OH NO! Don't gas it or spin the tires a little, the Flogging transmission will crack in two!!!!!
You gotta build it so you can side step the clutch at 4000 rpm and not worry about a thing.
jmo, ymmv, yes, I am nuts.
There's "drive it like you stole it" and "drive it like I own it"
Let's just say the first one is taking it easy compared to the second one.
OP has set the bar for sanity: 1948 F1 with a 3NINETY motor, Jag IRS, 18 or 20 inch wheels and 25 series tires.
How do you know how I drive? Did my old man talk to you or something? Sure, I broke an 8" in my high-mile Mustang when I first got it, but I never broke anything else..... (thank God for the strength of the C6 and 9er, and the weakness of a 283 in front of a PG/10 bolt)
There's a guy selling a T85 3+1 over on the Ford FE big block site in the classifieds now for $150. Don't know what shipping would be to the other side of the planet though.
Where are you located. I'm sure we can figure out a way to adapt a transmission to the fe motor.
What are you looking for. Manual or automatic. And how many gears are you loOking for. Do you really think you need overdrive. You're running 331 gears and a reasonably sized tire. Anything over 26" will cruise very well with that gear.
Anyway. What cars are available to use as donor cars.
#30
79F150/F600
33
03-31-2009 03:30 PM
bshackelford711
03-31-2005 01:21 PM
