problem with reverse light.
Old Jan 11, 2012 | 03:37 PM
severedevil's Avatar
severedevil
ok so both reverse lights didnt work, now i unplugged the sensor plug from the top of the tranny and plugged it back it, now the pass side rev light works. now the driver side doesn't. Ive messed with the wiring the best i could. nothing seems too bad but i just cant seem to get the wiring right. all the other lights work. brake, running, blinkers. but the driver side reverse just doesn't work. now when i unplug the sensor in the tranny and reverse it and plug it back in neither side works. normal?
input anyone?
trucks a 1989 F350 7.5L Dump truck,
Old Jan 11, 2012 | 09:41 PM
732t37's Avatar
732t37
Sounds like your issue is unrelated to the sensor. Since you have a dump body, open up all the wiring sheaths along the whole length and check for butt connectors that filled up with water and broke. That's a very common issue with upfitter bodies on any truck, esp. a 20-year-old one.
Old Jan 11, 2012 | 10:51 PM
cyborghunter's Avatar
cyborghunter
not to sound like a dick but um did ya check the bulb?
Old Jan 11, 2012 | 11:32 PM
ford2go's Avatar
ford2go
If the wiring and the bulb seem OK, it could well be the socket. Might not be getting a good connection ( often on the ground side), or it might be corroded.
Just a couple of thoughts,
hj
Slapshottr
Electrical Systems/Wiring
Jan 12, 2019 10:53 AM
beefey
Nov 25, 2017 05:06 AM
TheCoach
Jul 22, 2017 01:24 PM
ianobetz
Feb 27, 2016 03:37 PM
Fordzilla80
Aug 15, 2009 11:30 PM
