DIY Headache Rack, Bed Rails, Generator "Holder"
For several years now I've been continually getting annoyed by all the chips on the top of the bedsides, mostly from people I employ throwing ladders and conduit in any-which-way. So, I need bedrails.
Also, I wanted a headache rack because I like the look of them and also, it gives me a high-up place to mount tiny little strobe lights, helping with visibility while we're working around the truck or loading/unloading because people around here seem to enjoy driving over my cones and I'm tired of replacing them.
Also also, I wanted to mount a round 15-gallon DOT-legal tank I bought as well as a small portable generator *above* the bed so this way the bed is still completely useful for longer items - plywood backboard, conduit, and so on.
So with these three things in mind, and a plethora of curb-plucked exercise equipment (and some leftovers from past projects), I started building all three things as one complete unit.
How things will be mounted:
Making of the hoop:
First coat of paint:
The step by step is here if anyone is interested: Headache Rack / Bed Rails
I'm not too happy with the shape of the headache rack frame, but after spending several hours frustrated while trying to figure out where in the pre-formed bends I should cut, I went the "monkey route" and just hacked the sides up and called it a day. I can always cut it off and weld something else down the road if it annoys me that much.
I didn't build the insert yet and probably won't until spring but at least it's framed out and integrated with the bedrails and generator/fuel tank supports.
The tank is a DOT legal tank, and I visited the local state police to discuss the mounting of this tank in this fashion, and the two officers I spoke to had no issue whatsoever with my doing this, since the tank itself is DOT legal. The only thing they suggested is the tank should not extend past the roof line or the side of the cab, so during a roll-over the tank is very unlikely to be dented and/or punctured.
Of course if I'm pulled over we'll see how *that* officer feels about the legality of this DOT tank being mounted there.
So, that's as far as I got today. As part of this there will also be a waterproof, 250W halogen "light on a pole" that will be removable for driving and easily set up and run off the generator. The generator is a bit of an oddity - it provides 25A @ 120V (3000W) through a 15A duplex mounted on the generator head - after taking it apart to see how that could be, I discovered the generator has two windings, one connected to the top half of the duplex, the other connected to the bottom half of the duplex, with neutral in between. So that's 12.5A to each half of the duplex. Interesting I thought.
Making of the hoop:
The tank is for both the generator that will be mounted with it, but also for my bigger 15KW portable generator I put in a shed next to my house - that one has a 17 gallon tank and the idea of having multiple 5 gallon cans sliding around didn't thrill me, so this tank (which is 15 gallons) allows me to avoid all that.
I have the same issue. Most significant others are not fond of yard-stored "honeypots".
But that's okay, every so often I "thin" the piles, getting rid of the thinner, less useful stuff and keep the bigger stuff for projects like this. You can always cut a smaller piece out of a bigger piece
Received 3,163 Likes
on
The problem is, anytime I see gym equipment at the curb, I must stop, must load it, must take it home.
on
on
