1978 - 1996 Big Bronco
Removing The Stabilizer Arms...
Old Jan 11, 2012 | 02:08 AM
1990_Bronco_Custom's Avatar
1990_Bronco_Custom
I was wondering how bad it would affect my truck's road manners if I were to remove the front and rear Stabilizer Arms. Would there be little difference? Big difference? Or no difference at all?
Old Jan 11, 2012 | 08:12 PM
njneer1's Avatar
njneer1
I think you will notice a huge difference !
Old Jan 12, 2012 | 04:31 PM
Edgethis's Avatar
Edgethis
I would imagine it'd be a huge difference. even with worn out bushings they are helping more then not having any at all.
What would your reason for removing them?
Old Jan 12, 2012 | 09:23 PM
GruesomeJeans's Avatar
GruesomeJeans
The stabalizer bar is the same as a sway bar correct? If so you would notice a lot of body roll and when the wind blows the side of the truck it would probably wobble. People so it a lot to get more flex out of their suspension and get through some of the tougher terrain. Instead of just removing try unbolting the stabalizer/sway bar arm links from the frame and see how you like it and if it gets a bit hairy while driving, re attach them.
Old Jan 12, 2012 | 11:13 PM
1990_Bronco_Custom
That's exactly why I wanted to remove them. More Flex. I just didn't know how much it would affect the truck on-road. I always thought it depended on how fast you were going and how big of tires you had...
@GruesomeJeans- Nice '78 you have there
Old Jan 12, 2012 | 11:44 PM
GruesomeJeans
Thanks, ya if your doing city driving it shouldn't affect it too bad but if you go on the freeway you may run into some issues. the wind going along the sides of your truck can cause a lot of swaying (hence the need for sway bars), a friend of mine had a suburban that he took the bars off for more flex and when he went on the freeway, it would sway back and forth and he said it was sort of scary. Like i said if you unbolt the links but leave the bars on, when you get done wheeling you can bolt them on and be on your way. At least thats my theory.
Old Jan 13, 2012 | 12:41 AM
1990_Bronco_Custom
I think I'll give it a try the next time I wheel it. I also hear the longer Radius Arms help with Flex when it comes to a TTB.
Old Jan 13, 2012 | 08:39 AM
Edgethis's Avatar
Edgethis
Yes longer arms allow more flex.
Old Jan 14, 2012 | 01:09 PM
camekanix's Avatar
camekanix
I took mine off for more flex and never put them back on. I have had no problems at all and even noticed it glides over speed bumpos where 1 side hits but not the other more smoothly. I'm sure it would make a big difference is very sharp emergency type turns and braking turns where the rollover tendency would be greater but for everyday driving (including highway) I have not had any problems.
Old Jan 15, 2012 | 01:45 AM
GruesomeJeans
I would imagine it would flip a bit easier but i don't think anyone planes to try to turn fast in these monsters anyway. I think 20 is the fastest i will turn in a sharp one for the fear of tipping. I plan to unhook mine and see how i like it and if i find it suits my ride style i may take them off completely
Old Jan 15, 2012 | 07:44 AM
Edgethis's Avatar
Edgethis
I drove mine around a bit with the rear unhooked and didn't notice much body roll. I also was only doing about 30-35 tops. I plan to hook it back up since I bought all new parts, but wouldn't be afraid to take it off if I lifted it
Old Jan 15, 2012 | 10:15 AM
masseysbronco's Avatar
masseysbronco
Shouldn't be too hard to rig something up so that you can easily disconnect them before going out on the trail and then reconnect them for the street.....
Old Jan 15, 2012 | 10:40 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
You never know when you will have to take an evasive maneuver, you will do it without having time to think. Quick disconnects are made for about any sway bar for off roading.
Old Jan 15, 2012 | 03:13 PM
GruesomeJeans
If you wanted to do a homebrew quick release for it i'm sure you could get a small pin form the trailer hitch where it locks into the receiver and stuff those through the links so all you have to do is pull 2 pins and slide those mothers out and your ready to go. However my only concern would be the sway bar swinging down and catching on something. My way of fixing that would be some sort of duct tape and zip tie contraption...
Old Jan 15, 2012 | 05:44 PM
Edgethis's Avatar
Edgethis
The rear sway bar is only gonna go down and smack the top of the axle. it'll stop there. but the ends could catch on rocks or something
