1978 - 1996 Big Bronco
How to tell?
Old Jan 10, 2012 | 10:41 PM
GruesomeJeans's Avatar
GruesomeJeans
How to tell?
So is there an easy way to tell if you have a 351M or a 400M? I was decoding my vin through an LMC truck catalog and i have the letter H as my engine code which is a 351, but the PO said it's a 400 so i am not sure. I probably could tell from the code on the block but if there was a faster way that would be pretty nice.
Old Jan 11, 2012 | 03:08 PM
Edgethis's Avatar
Edgethis
Unfortunately the only way to really tell is to check length of stroke.
They are 100% identical visually.
It prolly has a 351m, most half tons had that instead of the 400.
Old Jan 11, 2012 | 05:01 PM
AzPete's Avatar
AzPete
You can check the stroke pretty easy. Pull a plug, insert a long plastic straw, rotate to top dead center and mark position on straw......rotate to bottom dead center......mark position on straw. Measure between marks. Install plug.
Old Jan 11, 2012 | 07:05 PM
Encho's Avatar
Encho
The Southernmost Mod
Lol that seems like quite an ordeal to find out just a number...
There is another way, dropping the oil pan, have a read:
http://www.fordification.com/tech/engineID-V8.htm
Old Jan 11, 2012 | 07:49 PM
AzPete's Avatar
AzPete
All depends how much one needs the correct number.....
Talk about work....dropping the pan...
Old Jan 11, 2012 | 08:26 PM
Encho's Avatar
Encho
Either way, too much job just to find out a number. Do you think he wants it that badly?.
Old Jan 11, 2012 | 08:45 PM
AzPete's Avatar
AzPete
Only needed if there were any size specific parts externally or for braggin' rights. And bragging could go either way depending on who is on the receiving end.
Old Jan 11, 2012 | 09:55 PM
GruesomeJeans
Haha actually i really wanted it more for bragging rights and for the correctness of my sig and other things. I prefer to say it's a 400 so i think i will stick to it till someone looks at it and say YOU LIE! :P i am not super concerned with it i was just thinking there may be a difference in the water pump or maybe the heads or something that i could easily look at. at the moment i can't drop the pan due to not having a backup vehicle to drive to work. Eventually i plan to have the motor rebuilt and the tranny rebuilt but i have to wait till i get my tax return.
Old Jan 11, 2012 | 10:11 PM
Encho's Avatar
Encho
With some parts you can actually convert a 351M into a 400, i've actually heard it's quite easy.
Old Jan 11, 2012 | 10:15 PM
GruesomeJeans
Besides the cubic inches, is there really much of a difference? I think i read somewhere that the 400 has a bit more low end torque but i don't know if it was true
Old Jan 12, 2012 | 09:05 AM
Edgethis's Avatar
Edgethis
More displacement =more torque in this case. The mpg will go down a tad once its tuned properly, if you don't tune it, it'll prolly run a bit lean.
If your gonna rebuild it you might as well. I believe its just the crank is different....maybe something else. Its been too long for me to remember.
Old Jan 12, 2012 | 08:53 PM
GruesomeJeans
Ah ok. On monday i am dropping my truck off at Aamco transmission so they can do a *free* inspection and tell me if it needs a full rebuild or just parts. I plan on just doing a full rebuild and putting parts in for towing and offroading. i just have to get a price and once i get my tax return i can look into getting that out of the way.
Old Jan 12, 2012 | 09:29 PM
Edgethis's Avatar
Edgethis
I plan to take my truck into Aamco to have my trans rebuilt, and I have ordered all TCI parts, rebuild kit and a new torque convertor. They have lots for your C6.....
Search results for: 'c6' - TCI® Auto
Old Jan 12, 2012 | 09:34 PM
GruesomeJeans
Dang they do have a lot. I might have to shmooze through and find some cool stuff. Unfortunately i don't know much on transmissions so i don't really know what to look for. I do know i want a new torque converter and flywheel/flexplate and that kind of stuff but i don't know what kind to get nor what internals to look for. I think once i get the verdict from Aamco i should be able to start picking out parts.
Old Jan 12, 2012 | 09:44 PM
GruesomeJeans
You know i would almost wonder if it would be worth it to buy a whole new one over rebuilding mine... I guess when i find out the price on mine i can decide
