Spout connector?
Old Jan 10, 2012 | 08:48 PM
penguintits's Avatar
penguintits
Spout connector?
Here is a picture a stole from someone else. This looks identical to mine, except one of the wires is cut on the female end. Where does it suppose to go to? I just bought this truck. This is the spout connector right? 1986 f150 4.9 I6
Old Jan 10, 2012 | 09:05 PM
penguintits
Old Jan 10, 2012 | 09:07 PM
Galendor's Avatar
Galendor
Yes, that is the SPOUT connector. In fact, it is the SPOUT connector on my truck!
Old Jan 11, 2012 | 06:29 PM
penguintits
Thanks! Now the wire on the female end of my spout connector is cut, where is it suppose to go? When I unplug the spout connector the timing should change correct? I'm assuming its not working because of the cut wire.
Also while I'm at it, where is the ISC Idle speed control located on the carburetor? The manual does not show it, only the curb idle speed adjustment and fast idle speed.
Thanks again.
Old Jan 11, 2012 | 10:33 PM
Galendor's Avatar
Galendor
Thanks again.
The wire on the spout connector goes into the TFI module sticking off the side of the distributor, hopefully the cut wire matches an identical-colored wire that has been cut there. The other end of the spout wiring goes towards the firewall.
I would also assume that its not working because the wire is cut. Cutting the wire is the same as disconnecting the spout...
Here is where the ISC speed control motor is:
Old Jan 12, 2012 | 12:33 AM
penguintits
Thanks for the info! Your getting me closer to solving this. On the SPOUT connector it is connected to the distributor but the other end has a red crimp going to nothing. I couldnt find a same colored wire near by, instead i found this mess. I found 4 wires connected to each other only by being twisted together. one wire goes to the coil, the other the coil resistor, then one the fire wall the other back end of the motor(either going to the firewall again or to the carburetor area. The other crimp comes from the coil resistor to the area behind the motor/firewall. I need a schematic!
I hope these help...
What is the SPOUT suppose to connect to? the computer right?
The last picture on the driver side fender has two separate connectors that are both yellow same as the SPOUT but i doubt they go to it being so far away.
The truck runs and idles, but dies under a load once I start moving.
Last edited by ctubutis; Jan 12, 2012 at 07:03 PM. Reason: Stacked pictures (easier to see)
Old Jan 12, 2012 | 08:03 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Archion has my 86 EVTM, I asked him to see if he can help.
Old Jan 12, 2012 | 08:08 AM
Archion's Avatar
Archion
Veteran: Marine Corps
If someone else doesnt beat me to it, I'll try to scan those pages tonight.
Old Jan 12, 2012 | 10:16 AM
penguintits
Thanks guys, that would help a lot.
Old Jan 12, 2012 | 07:00 PM
Archion's Avatar
Archion
Here ya go, I think I grabbed the most pertinant pages for ya.
Click ME!
I would have just attatched it, but FTE seems to be experiancing difficulties once again...
Old Jan 12, 2012 | 07:05 PM
ctubutis's Avatar
ctubutis
Not that I'm aware of!
Whazzup?
Old Jan 12, 2012 | 07:08 PM
Archion's Avatar
Archion
The pdf would not attach. Tried various permutations of the file name, knowing we are on a *nix server and they can be pissy about file rules, size was within limits as well... who knows.
Old Jan 12, 2012 | 07:10 PM
ctubutis's Avatar
ctubutis
Yeah.... i just tried to attach your pdf file to a post, all it tells me is:
Upload of file failed.
How helpful. *sigh*
OK, thanks for the notify, I'll turn it in to Tim & Co.
Old Jan 12, 2012 | 08:06 PM
85lebaront2
Chris, I had an issue with pdfs a while back, I finally ended up doing a jpeg instead.
Old Jan 13, 2012 | 02:20 PM
penguintits
Awesome! Thanks for the schematic! I'll try to go out and tackle this
