Sponsored by: Innova
2001 Navigator audio install help
Old Jan 10, 2012 | 08:32 PM
68bluebeast's Avatar
68bluebeast
I have a 2001 navigator and I bought a pioneer AVH-p4300dvd to install in it. I have installed many head units but never one like this so I have a few questions. I have a navigator so obviously have the premium sound in it, I know it has an amp running the factory sub (not working) but I do not know if it has a amp running the speakers. Do navigators have a factory amp that runs the speakers? if so I would like to bypass it. I do not want to mess with splicing into the parking break wire for the dvd so if I just ground the parking break wire form the head unit then the dvd should work correct? On the wire harness for the head unit it has a wire that says reverse postions and to hook up to back up lights, that is just for a reverse camera right?
Old Jan 31, 2012 | 11:51 AM
ItsMREMT's Avatar
ItsMREMT
1) yes you have amps for your door speakers and one for your sub.
2) yes you can bypass it but it will be a pain to do so. ( you will have to run speaker wire from each speaker to the radio). it would be simpler to get a radio harness and just plug your new pioneer into the existing stock harness
3) not sure grounding your pioneer will work that way you might have to have a toggle switch connected to a ground. does your pioneer run off of windows? if so you can do a software hack so it will only prompt you pull over to use gps or DVD if going over 150
4) not sure on the reverse position thingy
Old Feb 13, 2012 | 08:51 AM
spastik monkey's Avatar
spastik monkey
reverse position is for the reverse camera feature
Reid Gordon
Dec 1, 2016 04:27 PM
makenagillies
1978 - 1996 Big Bronco
Aug 30, 2016 01:37 PM
PPrash
Jan 6, 2011 09:22 PM
digitalamish
2009 - 2014 F150
Jun 12, 2009 10:53 PM
SirDino
Jun 19, 2003 10:32 PM
