tailgate LED's
Old 01-10-2012, 08:02 PM
danorules's Avatar
danorules
danorules is offline
tailgate LED's
here you go; i put in a three pack of LED's and mounted them between the bumper and tailgate. a triple bar does not have enough clearance, so i got single 3/4" recessed grommit mounted LED's
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
real easy install. found the center line, and then marked a spot 6" out on both sides, dropped the spare tire out of the way, drilled three 3/4" holes, installed grommits, installed led's, wired them together, ran the ground to the frame, and stole the hot from the license plate light, reinstalled the sparetire.
also aired up the tire while it was down and greased up the cable and mechanism for the spare
Old 01-10-2012, 08:05 PM
Coskid's Avatar
Coskid
Coskid is offline
Nicely done they look good!
Old 01-10-2012, 08:07 PM
Ford Agian's Avatar
Ford Agian
Ford Agian is offline
Looks SHARP Dano nice job
Old 01-10-2012, 10:21 PM
tooldad's Avatar
tooldad
tooldad is offline
Looking good!
Old 01-11-2012, 12:23 AM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
Looks good...nice clean work.
Old 12-29-2012, 03:05 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Bump!
Dano, do you have any other pics of this mod? Close-ups of the actual LED's perchance, wiring, etc?
Stewart
Old 12-30-2012, 02:31 AM
danorules's Avatar
danorules
I don't. If I get a chance I will pop under there and try to get some pics
Old 12-30-2012, 09:52 AM
2012 SD Snowbuster's Avatar
2012 SD Snowbuster
2012 SD Snowbuster is offline
Dano-
Thanks for posting that, now my RECON line of fire led light strip looks weak...lol Looks good!! Happy New Year!!
Old 01-01-2013, 08:15 PM
chunnih's Avatar
chunnih
chunnih is offline
how do i download the manual for my 2004 f150 triton
happy new year to all,
i need the manual so i can fix my tail lights, i may have to replace the fuse, i do not know which one
Old 01-02-2013, 07:50 PM
signsbystormy's Avatar
signsbystormy
signsbystormy is offline
How much did that run you?
Old 01-02-2013, 08:36 PM
danorules's Avatar
danorules
$20 all together. That includes the 3 leds, wires, and butt connectors with the shrink seal. I have had them for a year now with 0 problems.
I will try to post up better pics and better angles this weekend.
mmpossum
12-25-2012 09:32 PM
roger dowty
1978 - 1996 Big Bronco
03-26-2006 10:54 PM
MORTORQUE
09-23-2004 09:35 PM
Nate1
03-09-2003 12:00 PM
Oceanwave
Bronco II
01-11-2003 04:49 PM
Quick Reply: tailgate LED's
