Sponsored by: Real Truck
V10 running rough
Old Jan 10, 2012 | 02:43 PM
Epd444's Avatar
Epd444
V10 running rough
My 99 F250 with a v10 just started to run and idle rough. Throws no check engine lights or anything. I know the exhaust is aftermarket, and starting to rot out. The exhaust had an strong odor to it, almost like fuel. It kind of spits and sputs at the lower RPMs, but it seems over 2,000 RPMs its not as bad.
Any ideas what to check? Even if the exhaust was rotted out, would that cause it to act up like this?
Old Jan 10, 2012 | 06:02 PM
redford's Avatar
redford
FTE Leadership Emeritus
Idle Air Control valve (IAC)
Old Jan 12, 2012 | 03:57 PM
Epd444's Avatar
Epd444
It runs fine above 2,000 rpm. At about 1200 to 1800 rpm it runs rough, shakes the truck when driving, and idles kinda funny with a strong fuel odor.
Old Jan 12, 2012 | 04:15 PM
IslandBlueV10's Avatar
IslandBlueV10
Sounds like a bad coil or two. I had the same thing about those same rpms but would run better at higher rpm. Took it to ford and they couldn't find anything wrong. Then took it to another mechanic it took him 4 days to figure it out. Finally I told them to take it to the mountains I was on when the problam showed up. It would act up the most when under a load around 1500rpm. The mechanic had a laptop hooked up to the truck for the drive, and found the problem was coil #4 and 9 was bad. I know bad coils are hard to find. I have 2 diffrent scanners and no codes ever came up, or check engine light.
I don't think the exhaust has anything to do with the problem. Might be a good time to do a good tune up.
jshalala
Feb 16, 2014 10:43 PM
salty88
Oct 14, 2012 08:26 PM
SuperDutyKS01
May 15, 2009 08:58 PM
derwolf
Modular V10 (6.8l)
Dec 15, 2007 07:25 PM
wrecking_crue
Apr 14, 2007 10:05 PM
