Backfire through throttle body. Timing problem?
Old Jan 10, 2012 | 08:50 AM
x_man586's Avatar
x_man586
If I rev the motor to 3000+ and let it drop to 1000-1500 then rev again it pops really loud from around the TB. I know I have the timing set to 10*btdc, but the chain probably has 200k miles on it. Could that be the problem?
Old Jan 10, 2012 | 09:06 AM
lavatan's Avatar
lavatan
If it backfires through the carb it means the timing is too retarded and the intake valve is still open when it fires. I would guess, that yes, the timing chain has too much slack and that is why you get this problem after you rev it like that. I would take the timing cover off and check the chain. Replacing the timing chain can be a PITA but better than a blown engine.
Old Jan 10, 2012 | 09:32 AM
x_man586's Avatar
x_man586
It is not carbed, but that doesn't matter. I also have an oil leak from around there, so I have another reason to pull off the cover anyway.
Old Jan 10, 2012 | 09:39 AM
lavatan's Avatar
lavatan
Let us know what you find. I'm not sure what the tolerance is for your engine regarding chain slack, but you should be able to tell if it's too loose by eye.
Old Jan 10, 2012 | 09:49 AM
x_man586's Avatar
x_man586
I'm going to run some seafoam through it this weekend and see if that does anything. Might just have some carbon buildup on my valves.
Old Jan 10, 2012 | 03:00 PM
Leaf's Avatar
Leaf
I've had some of my junkercycles backfire through the carbs when the mix is too lean and I snap the throttle closed too fast. That was with CV carbs though, so no idea if it applies to these trucks or not....
(Indeed, I prolly oughtta keep my mouf shut about stuff I don't really know anything about, eh? :P )
Old Jan 10, 2012 | 04:14 PM
x_man586's Avatar
x_man586
keep your mouth shut and not express ideas/opinions or post questions and you won't learn anything.
samtye
Nov 2, 2007 02:30 PM
kameronth
1978 - 1996 Big Bronco
Jul 10, 2004 03:44 PM
rfgree
Dec 31, 2002 10:34 PM
rayray2k22002
Dec 2, 2002 07:53 PM
