Oil & Lubrication
Valvoline
Old May 27, 2003 | 10:44 AM
TallPaul's Avatar
TallPaul
Valvoline
Originally posted by MScotty
I've been using Valvoline Dura-Blend 5w-30 in my 96 Explorer since day one. When MaxLife came out I though of switching, but wasn't sure about going from a blended oil back to a dino.
I called Valvoline's tech line and was told if I've been using Dura-Blend then stick with it, it's a better oil than the MaxLife.
I appreciate you passing that Valvo. tech. quote along. I have been using Dura-Blend 5w30 in all my vehicles for several years now and have no desire to switch. Also, I always run a quart of Rislone, which is essentially a 5W-20/25 oil base with extra additives. So maybe I am getting the best of both worlds with this setup. I still generally change the oil every 3000 though.
PS. I have had Valvo Techs tell me some rather interesting things. I believe (searching my memory) they indicated a high ratio of synthetic to their DuraBlend (30-40% I think) and that they did not get to supply the Motorcraft oil because they are too expensive (implys Valvo may be better than the stuff labeled Motorcraft?).
Old May 28, 2003 | 06:21 AM
MScotty's Avatar
MScotty
Valvoline
TALLPAUL,
Thanks for your input towards Dura-Blend too.
Valovline's tech. line is pretty good, ask them a question and they'll give you a straight answer.
Mobil Syn-Blend is now being made for high mileage vehicles(or so the label says), but only in 10w-30. I'd wonder if Valvoline might do the same think.(I haven't tried to ask them yet.)
Old Jun 9, 2003 | 12:11 AM
punchy1's Avatar
punchy1
Valvoline
i've been using max-life 10/30 in my '77 ford 302 primarily since it came out. i have a rear main small leak along with other various leaks (the guy who had it before me didn't take care of the girl!). i'm getting the leaks one at a time (changed valve gasket yesterday). i've used other oils occasionally when i couldn't get the max, but i can say that the valvoline definitly slows the leak down. so its definitly not a cure, but i'm not gonna use anything else. no complaints. suggestion buy by the case.
fearfactory
Oil & Lubrication
Mar 30, 2006 11:15 AM
Avanti
Oil & Lubrication
Aug 18, 2005 01:07 PM
drumlinecowboy
General Automotive Discussion
Mar 6, 2005 08:25 PM
blownbronco
Oil & Lubrication
17
Dec 24, 2002 03:56 PM
92Custom
Oil & Lubrication
Mar 26, 2002 12:09 PM
