Engine brake on a cab chassis?
Old Jan 9, 2012 | 11:20 PM
hay is for horses's Avatar
hay is for horses
Do the cab chassis come with the engine brake? sorry if this seems a dumb question!
Old Jan 10, 2012 | 12:08 AM
TRENT310's Avatar
TRENT310
You mean exhaust brake? I think any vehicle with a transmission the driver can control features engine braking...
Old Jan 10, 2012 | 03:55 AM
hay is for horses
sorry ok exhaust brake
Old Jan 10, 2012 | 08:08 AM
Tom's Avatar
Tom
Typically the term "engine brake" refers to a Jacobs-style braking system that uses altered valve timing to retard the engine and provide a braking force.
I believe the cab-and-chassis trucks use the same system that the pickup truck models do, which introduces backpressure into the exhaust manifolds by actuating the VGT vanes. This is activated by putting the transmission in "tow/haul" mode and stepping on the brake. The transmission will downshift and the truck's PCM will add backpressure as necessary to control the speed going down a hill.
It's not the most effective thing out there, but it's a bit better than the system on previous trucks.
Old Jan 10, 2012 | 05:15 PM
hay is for horses
Thanks again for the info!!
Old Jan 10, 2012 | 08:24 PM
jim48's Avatar
jim48
I use the braking when towing the 5th wheel and going down grades like at Flagstaff, Arizona- California border and coming down Tehachapi. I get my speed at no more than 50 mph at top, tap tow/haul and tap the brake pedal once. This works great for me. There is one place coming down Tehachapi I have to tap the brake the second time but that's the only place.
I know some say the braking on this truck isn't really any good. It seems to work OK for me. I've never owned a Chevy or Dodge so I'm the wrong one to do a comparison. I'm sure Chevy and Dodge braking system is good, I've just never owned one.
Old Jan 11, 2012 | 05:31 PM
Chilly-in-Vermont's Avatar
Chilly-in-Vermont
My 6.7 doesn't seem to have any exhaust braking, either with my 5th wheel or without any trailer. I also have complained about turbo lag and get to story if it doesn't throw a code it must be ok. I only throw that in as I am told that the "exhaust braking" is done thru the turbo and I have seen postings of turbo noise and problems.
Old Jan 11, 2012 | 06:04 PM
Tom's Avatar
Tom
It's not that significant, to be honest I wasn't very impressed. Ever since the 2003 introduction of the TorqShift 5R110 transmission and 6.0L diesel there has been a downshift/engine braking strategy built into the transmission programming while in tow/haul mode. My 6.4L had the same thing, but never any advertised exhuast braking. When coming down a hill with my 6.7L and loaded trailer it fared only marginally better than my 6.4L with only compression braking. It's not that noticeable of a thing, so I doubt yours isn't functioning right.
Old Jan 11, 2012 | 06:49 PM
RogerM's Avatar
RogerM
After learning how the brake works it does work well. The trick is to get the RPM's up to around 3000. It will go through downshifting and work well when the the r's up. I was pulling my 5th. wheel last fall for about 2500 miles and got the process down pretty well. In the 3000 roange you will be in 3rd. gear and holding around 50 mph.
I dorve the chevy before buying the ford and was very impressed with their system, a true ehanust brake.
kajolley
6.7L Power Stroke Diesel
Jan 9, 2018 12:09 PM
Robert AR
Feb 6, 2016 02:03 PM
IHpuller450
Dec 30, 2014 02:11 PM
ALedbetter1
General Diesel Discussion
Oct 12, 2013 01:09 PM
hedhntr
Mar 30, 2006 09:00 AM
