what problems do short commutes pose?
Old Jan 9, 2012 | 08:19 PM
katesdad's Avatar
katesdad
as it says, what problems can arise from short, daily commutes? thanks
Old Jan 9, 2012 | 10:05 PM
Tom's Avatar
Tom
Hi katesdad, welcome to FTE!
The two issues that I'm aware of have to do with the temperature the engine is running in. The engine oil can accumulate some contaminants such as diesel fuel and moisture that normally will burn off when the truck hits operating temperature. If it never gets warm these contaminants can cause issues with rust as well as fuel dilution that can cause bearing damage.
The other issue is the fact that when the engine runs cold certain sensitive systems such as the DPF, turbo, and EGR valve are prone to get gummed up with carbon and soot. The DPF, in particular, requires full-temperature operation every so often to clean out the soot. If driven for an extended period of time without any required regenerations the DPF can get permanently plugged up. Warranty would likely cover the repair, but out of warranty this is an expensive repair!
What are your driving conditions like?
Old Jan 10, 2012 | 10:04 AM
Thom12's Avatar
Thom12
In addition to the good points Tom posted, the exhaust system needs to get hot too in order to prevent premature rust out.
2010F350
6.4L Power Stroke Diesel
Sep 6, 2010 10:05 AM
Roylee77
May 20, 2009 12:53 PM
alremkin
Feb 16, 2009 11:02 AM
lazy ike
Apr 14, 2008 10:46 PM
buckarooboy
Nov 15, 2005 04:55 PM
