Oil leak
Old Jan 8, 2012 | 11:15 PM
Fairbanksmiller's Avatar
Fairbanksmiller
Oil leak
Just replaced the hpop, turbo pedestal orings top and bottom, ebpv rebuild, turbo sensor orings, oil rail plugs, fuel bowl orings, oil fill tube, and innercooler orings and gaskets. Ford replaced the rear main seal about a year ago. The rear oil galley plugs appear to be dry. Still my truck pours oil out running off the bell housing. Any ideals?
Old Jan 8, 2012 | 11:16 PM
Fairbanksmiller
1999 7.3 powerstroke 177,000 miles
Old Jan 9, 2012 | 12:24 AM
Bonanza35's Avatar
Bonanza35
HPOP lines. One may have a hole in it. Also the fuel line that runs next to the head passenger side get holes in them to, but this is fuel. Under the glow plug relay. It coming from the valley right?
Chet
Old Jan 9, 2012 | 12:33 AM
Fairbanksmiller
Hpop lines are clean and dry. Definitely oil. Maybe a cup in five minutes.
Old Jan 9, 2012 | 07:10 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Wash the crap out of it top to bottom and then start it and watch. If it's leaking that much it should be easy to spot it it's cleaned up first.
Old Jan 9, 2012 | 08:07 AM
Rose Clifford's Avatar
Rose Clifford
yep, i'd start around the HPOP....wash it down and stuff some clean rags around it and all the hoses/plugs and see which one comes out dirty when you pull them out.
Old Jan 9, 2012 | 12:17 PM
Fairbanksmiller
Yea that's the problem. I just replaced all that two days ago and cleaned the entire valley. And valve covers when I did it. It was all leaking alittle but hasn't fixed the most if the problem. I can't get a mirror down to the rear of the heads but that is about all that is left. Oh yea, i also replaced the ccv orings.
dothedew192
26
Jul 28, 2011 09:43 PM
iggipsd96
Oct 22, 2009 11:14 PM
LookoutRanch
May 24, 2009 06:51 AM
andt350
Jun 6, 2007 08:00 PM
300inline6
Oct 15, 2004 02:14 PM
