P2182- Engine Coolant Sensor
Old Jan 8, 2012 | 06:06 PM
lexustbs's Avatar
lexustbs
P2182, has anybody else had this problem? I have an appointment to have it looked at tomorrow. Its says on the code reader engine coolant sensor. I also plan to tell the dealer about some rough shifting. Only thing is, I just passed 36,000 miles, but the light came on around 35,900 so I took a picture. Do you think I will have a problem getting it warrantied?
Old Jan 8, 2012 | 06:12 PM
Hdslider's Avatar
Hdslider
Warranty. Really depends on the dealer, being that close and your pic I would hope they would.
Old Jan 8, 2012 | 06:30 PM
dschuffert's Avatar
dschuffert
I agree with Hdslider. It all depends on your dealer. I know one dealer in my area that would work with me and another dealer on the other side of town that would tell me too bad.
Old Jan 8, 2012 | 06:33 PM
p12483's Avatar
p12483
Wouldn't he still be covered anyways. Thought the motor was 5 yr 100,000 mile warranty?
Old Jan 8, 2012 | 06:36 PM
dschuffert's Avatar
dschuffert
Good point, now I am not sure, I'll have to look that up.
Old Jan 8, 2012 | 07:31 PM
Hdslider's Avatar
Hdslider
Engine is covered. Not electrical sensors.
Old Jan 8, 2012 | 08:10 PM
Tom's Avatar
Tom
Some are, but apparently not this one.
Originally Posted by warranty guide
(4) Your vehicle’s direct injection diesel engine and certain engine components are covered during the PowerStroke Diesel Engine Coverage Period, which lasts for five years or 100,000 miles, whichever occurs first. The following parts are covered during this extended coverage period: the engine, cylinder block, heads and all internal parts, intake and exhaust manifolds, timing gear, harmonic balancer, valve covers, oil pan and pump, water pump, fuel system (excluding fuel lines, fuel tank and frame mounted fuel conditioning module sometimes referred to as the frame mounted pump/filter/water separator), high pressure lines, gaskets and seals, glow plugs, turbocharger, two-stage turbocharger assembly, turbocharger actuator, powertrain control module, engine control module, high pressure fuel injection pump assembly, electronic driver unit, injectors, injection pressure sensor, fuel rail pressure sensor,high pressure oil regulator, exhaust back pressure regulator and sensor, exhaust pressure sensor, manifold pressure sensor, intake air temperature sensor, crankshaft position sensor, camshaft position sensor, accelerator switch.
Old Jan 8, 2012 | 08:18 PM
lexustbs's Avatar
lexustbs
But being so close, and the light coming on before the 36,000mi should get me in the clear. I hope?
Old Jan 8, 2012 | 08:27 PM
Indigofarm's Avatar
Indigofarm
I would think so. Where are you going. Curious since I am close. You can just give one portion of the name and I can figure the rest, or pm me
Cheers
Old Jan 8, 2012 | 08:28 PM
kper05's Avatar
kper05
Yeah, will depend on the dealer.
I think the picture will help.
Same thing in my area.
My dealer I know would work with me depending on the circumstances, the other probably wouldn't.
Glad the other was bought up by the good dealer a few weeks ago although now there's no competition.
Cheezit/Vloney, does the computer log a date/time when a CEL occurs where you can read it in IDS?
Old Jan 9, 2012 | 12:30 AM
PowerStrokeHD's Avatar
PowerStrokeHD
P2182 relates to a issue with the ECT sensor for the secondary cooling system, aka ECT2. It should be covered under warranty with no issue and in your case it should fall under the emissions warranty based on your current mileage.
ECT Sensor Warranty Coverage...
0 - 36,000: Bumper to Bumper Warranty (3yr/36,000)
36,001 - 50,000: Emissions Warranty (5yr/50,000)
50,001 - 100,000: Diesel Engine Warranty (5yr/100,000)
Old Jan 9, 2012 | 08:01 PM
lexustbs's Avatar
lexustbs
Today they found out the secondary coolant temp senson was bad, and also the thermostat was bad on the same system. Warranty covered it as well as my transmission issues in which they ordered some solenoids. I'll report back after I get my truck back tomorrow.
lkbenson
6.7L Power Stroke Diesel
Jun 13, 2017 07:31 AM
sscarboro
Aug 24, 2011 05:41 PM
alstang1
23
Feb 22, 2011 05:23 PM
BEBOB
1983 - 2012 Ranger & B-Series
Nov 15, 2005 10:02 PM
apairajeans
Escape & Escape Hybrid
Sep 13, 2004 12:47 PM
