1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Climate Controls swap.
Old 01-08-2012, 12:23 PM
remlle's Avatar
remlle
remlle is offline
Im sure this may have been asked but I have searched for over 20 mins and cant find anything.
I just purchased a 2004 Ford Superduty F350 it has everything I wanted except the digital air controls. Id like to know if i could swap out a digital air controls from another f350 or 250 from the same year and have it work or is there more to it then the module itself? thanks for the info and let me know.
Old 01-08-2012, 12:47 PM
PA-Mark's Avatar
PA-Mark
PA-Mark is offline
sure its possible
You may not like all thats involved in the swap thow, good luck with your quest
Old 01-09-2012, 07:03 PM
remlle's Avatar
remlle
remlle is offline
Well what all is involved?!
Old 01-09-2012, 07:18 PM
PA-Mark's Avatar
PA-Mark
PA-Mark is offline
you will need to remove the dash, replace the HVAC box, add the extra wireing harness, new climate control unit (which I have one for sale BTW) and a new radio trim bezel.
Im sure there is more but once I found this much out, I decided i did not need the dual zone anymore. If you are up to the task and have a donor truck then I wish you luck.
Old 01-09-2012, 07:52 PM
remlle's Avatar
remlle
remlle is offline
I don't want dual zone I want a digital control that's all
Old 01-09-2012, 07:55 PM
PA-Mark's Avatar
PA-Mark
PA-Mark is offline
my mistake, the only digital controls i have ever seen were in the dual zone control, so i assumed this was what you wanted
Old 01-10-2012, 02:14 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
I think PA MArk is right that a large part of the system has to be changed in order to have the EATC system whether single or dual zone. There was a thread about this a while back.
I have 2 different fords with that style auto climate controls and do not think I want another. Its great when it works but the control head is not very reliable IMO and its expensive. On the Mercury Grand MArquis we had, it went bad and acted like a vacuum leak where the vents went to defrost at will. 18 months after replacing it, it went bad again. Same thing with a truck we used to have. We usually just set it between 68-70 and never messed with it other than fan speed. I decided then that the we would not have another Ford with that style control head. I cannot find the receipt to compare P/N's, but the control heads for the 2 looked just alike.
Old 01-10-2012, 01:40 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
Basically, the controls are different, the cab wiring harness is different. The engine compartment wiring harness is different. There is an external temp sensor. There is an internal temp sensor that is part of one of the vents, not sure which one, but also has an opening in the dash to pull air in, so the dash is different. And the fan speed controller is different.
Old 01-11-2012, 04:19 PM
remlle's Avatar
remlle
remlle is offline
so basically way more work then just the controller that blows. oh well Ill make with what I have
Old 01-11-2012, 07:43 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Yes Mark is correct, it's a huge job and not just changing the controls. I ask a A/C engineer about that same thing, he said you need to get the whole system. With the digital it comes with the duel which means there are 2 bezels that control who gets what air and how much. He said it is not worth the work to switch over. If you really want it, should have found a truck with it already installed from the factory.
Old 10-22-2015, 01:11 PM
cumminpwr11's Avatar
cumminpwr11
cumminpwr11 is offline
bringing this back from the dead.
So I found two limited excursion that were rolled over. I can get all the parts from them for cheap, I just not sure what all is needed. I would like to do this swap too if possible.
May be silly but I would like to add a better steering wheel with radio controls and having the climate controls on the steering wheel bother me if they don't work.
Thanks
Chris
Old 02-18-2019, 02:47 PM
mickelsons's Avatar
mickelsons
mickelsons is offline
Chris,
Did you ever do this conversion? I am interested in doing it on a 2002 for the same reasons, I want the factory steering wheel volume controls. Again I agree may sound silly to some, but it's something I would like to see if it can be done.
EXSwap
04-27-2022 10:28 AM
CanadianSmokie
12-04-2007 07:11 PM
NY-Ford-Lifer
2004 - 2008 F150
26
10-26-2004 02:48 PM
04F250CC60
07-12-2004 03:00 AM
Quick Reply: Climate Controls swap.
