Offroad & 4x4
Track Bar Options
Old Jan 8, 2012 | 10:43 AM
Built_Ford_Tough_757's Avatar
Track Bar Options
I'm doing a straight axle swap in my 1985 F150, using a 1979 Bronco Dana 44. 6" of lift. I have everything figured out except for the track bar... One friend said he used a stock F350 track bar, but that sounds like it would limit my flex. What would be the best thing to do for my project?
Old Jan 8, 2012 | 07:44 PM
BrianDguy's Avatar
BrianDguy
What makes you think that the F350 track bar would limit flex?
Old Jan 8, 2012 | 08:00 PM
Doesn't the F350 bars bolt to the TTB location instead of the driver side frame? just seems to me it would limit the axle flex.
Old Jan 8, 2012 | 11:30 PM
thekingofcows's Avatar
thekingofcows
I have never done a solid axle swap on any vehicle originally equipped with ttb, but in any case the longer your track bar is the better, it needs to be parallel with your drag link.
I made mine out the original track bar and a peterbilt truck tie rod, but that is only because I had it laying around at the time... some DOM and heims are prime candidates for custom track bars.
I'm sure others will chime in with creative, or other proven (better (or not so better)) solutions.
Old Jan 8, 2012 | 11:39 PM
alpha/omega's Avatar
alpha/omega
1.5 x .250 DOM
1 LH and 1 RH 7/8 threaded inserts
1 LH and 1 RH 7/8 thread 3/4 body kevlar lined heims
Some angle and plate to build upper and lower mounts
Use a broom stick to measure angle and appropriate mounting locations. Driverside frame rail to passenger side axle tube and as close to parallel to the drag link as possible.
Old Jan 17, 2012 | 06:58 PM
How are heim joints measured? example, 3/4" is the hole where the bolt would slide through it?
Old Jan 17, 2012 | 11:30 PM
alpha/omega
Bore is the hole size and thread is obviously the threaded portion size.
Id get a 7/8 thread 3/4 bore kevlar lined heim
FordF350Baby
Sep 9, 2020 09:42 PM
JTyler11688
Jan 8, 2009 09:14 AM
69 F100 4x4
Sep 12, 2002 11:40 AM
monster86f250
May 20, 2001 07:17 PM
