Ignition Problems
Old Apr 18, 2003 | 08:28 PM
78F1504x4460's Avatar
78F1504x4460
Question Ignition Problems
I have an 85 F-150 with an 84 302. Well I just rebuilt the engine and got it running today, and decided I would take it for a test drive. When I was leaving, I hit a rough spot in the driveway and the engine died, and this is after letting it run at idle for about 2 hours.
Well anyway, I got to checking, and I wasn't getting any spark now The engine has a Mallory Uni-lite distributor and a Promaster coil. I got to checking my power leads, and I found a light power source on the - side of the coil so I took the power wire off and raked it across the + side of the battery and it arcs so now I have a ground. So any comments or any way of finding a ground would be greatly appreciated.
Thnks Alan
Old Apr 18, 2003 | 10:38 PM
kc5zom's Avatar
kc5zom
Ignition Problems
You found positive voltage on the ground wire ("light power source")? If you are just looking for a place to ground then do it directly to the block (where your negative battery cable should be attached).
BTW... It is very dangerous to create arcs right next to a battery, even the maintenance free ones have a possibility of explosion. If you want to see sparks just touch the exposed steel anywhere (away from the battery), that should all be grounded (or invest in a multimeter, even better).
Old Apr 18, 2003 | 10:50 PM
Mil1ion's Avatar
Mil1ion
Ignition Problems
Alan, Please read this .
https://www.ford-trucks.com/forums/s...hreadid=108536
It is posted at the very top of this forum
