Bear Claw Door Latches
Old Jan 7, 2012 | 11:24 PM
gt40racing's Avatar
gt40racing
Is anyone using these and what kit did you buy. I have a 51 ford F1 and need a source. Thanks in advance....
Old Jan 8, 2012 | 12:29 AM
Moe Craig's Avatar
Moe Craig
I haven't bought or installed them yet but since I want to keep my door handles, so I'll use the Altman Easy Latch
Old Jan 8, 2012 | 07:39 AM
jniolon's Avatar
jniolon
old and in the way
GT
here's mine
INSTALLING BEAR CLAW LATCHES IN A '53 F-100
john
Old Jan 8, 2012 | 08:46 AM
sdetweil's Avatar
sdetweil
and sometimes the pulls fight against the pressure on the latch from the door gasket.. (like in my case)..
I had 80-lb can type pulls and they couldn't open the door.. and stuck in the pulled state. and they made this terrible THUNK when triggered..
I even tried a pulley to double the pull power.. no success.
I found these gear driven, dual plunge motors and they are silent and work perfectly.. I am using braided pull wire..
http://www.avsontheweb.com/product.p...cat=138&page=1..
I paid $60 for the set in 2009.
Sam
Old Jan 9, 2012 | 08:08 AM
thepitshop's Avatar
thepitshop
I used a unit from rocky hinge, it comes with the latches and solenoid all built into one unit, keyless entry and installation kit for $215 bux, if you use the search function i do have a thread on the installation of this kit.
Old Jan 9, 2012 | 09:23 AM
CharlieLed's Avatar
CharlieLed
X2...Altman is the only way to go if you wish to maintain the functionality of your OEM outer door handles. I used them on my 56 and I am very happy with the quality and fit.
Old Jun 25, 2014 | 03:54 PM
jerryst's Avatar
jerryst
broken 55 door lock
The driver side door lock is broken. I want to buy new door locks, Does the ford f100 door lock interchange with other models. Like thunder birds of the same year? The doors and ignition where different keys when I got the truck. Trying to do this repair most economical way possible.
Thanks
Jerryt
Old Jun 25, 2014 | 03:55 PM
jerryst's Avatar
jerryst
sorry I posted that on wrong post
Old Jun 25, 2014 | 06:09 PM
gdub's Avatar
gdub
Here's how I did mine. Took a little fabricating but nothing too bad.
https://www.ford-trucks.com/forums/1...l-handles.html
jonf
May 26, 2013 06:45 PM
zeke51
Mar 6, 2010 05:30 PM
7.3 Rocket
Garage & Workshop
Feb 3, 2009 09:58 PM
Joker50
May 28, 2008 03:29 PM
