77' f150 6.0 engine swap
Old 01-07-2012, 10:20 PM
shorty2tall's Avatar
shorty2tall
shorty2tall is offline
ok so my plan is to do a engine swap on my 77f150.
Before i start i need some info.
Has anyone done a ford v8 diesel swap in there truck?
Is the frame on a 02 SD the same as what frame would be on a o3-o7 truck? reason i ask is i have a 02 to get a few measurements off.
i know ill need to swap my axles to dana60's what is the best year to find them from? if any one has info or know where i can find info please post links.
i will be using a zf-6 any info on how any one has done a zf-6 in theres cummins swaps would be awesome.
thanks guys!
Old 01-08-2012, 10:35 PM
shorty2tall
bump
ok well anyone have info on dana 60 swap to a f150 to support the weight?
Old 01-08-2012, 11:35 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I'm not sure if anyone has swapped a 6.0 into anything. I do know there is a ton of wiring involved in a PSD swap.
Jeff's Bronco Graveyard has radius arm mounts for the D60, you will have to figure out what to use for springs though as the 6.0 is heavier than anything Ford put in the front of that truck from the factory.
JustFarming
1999 to 2016 Super Duty
09-18-2019 05:35 PM
Caveman84
02-26-2011 03:39 AM
jermyjudge
Offroad & 4x4
21
05-04-2008 12:01 AM
Quick Reply: 77' f150 6.0 engine swap
