Rear Sway Bar
Old Jan 7, 2012 | 09:11 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
Rear Sway Bar
When I backed the '05 into the garage this evening, I heard a clunk when going over the bump into the garage and also once I started jumping a little on the running board.
At first I was thinking it might be shocks, as they are still the factory ones, but at 57k, it seems likely that they're bad but not like clunking bad.
Then I got to wondering, I believe it has a rear sway bar being an '05 with the tow package. A long time ago, I would get in my '02 and go over the end of the driveway and get a clunk from the front. Replaced the front sway bar end links and it fixed it.
Does the factory rear sway bar have end links like the front that could go bad and make such noises?
Thanks,
Jon
Old Jan 7, 2012 | 09:42 PM
njneer1's Avatar
njneer1
Yep.....sure do
Old Jan 7, 2012 | 10:19 PM
Sunline Fan
Thanks! Sounds like another job I need to get done now...
Old Jan 7, 2012 | 10:39 PM
white Buffalo's Avatar
white Buffalo
Your '05 is a V-10 so I'm not sure, but did you check your exhaust? I know this is comparing apples to oranges but on my 7.3L exhaust it seems like once a year I need to adjust the hod down points after I hear cluncking coming from the rear mount as it moves and hits the rear springs or the tranny crossover mount.
Old Jan 7, 2012 | 10:46 PM
Sunline Fan
Hmm, interesting. I haven't checked the exhaust, but I kinda doubt that would be it. I don't remember that noise before, and it hasn't been out on the road since September, so it couldn't have really vibrated loose. I'll look into this though, thanks!
Old Jan 7, 2012 | 10:51 PM
njneer1's Avatar
njneer1
Does your parts Ex have a rear sway ?
Old Jan 7, 2012 | 10:56 PM
Sunline Fan
No, it doesn't. I don't believe it was a factory option at that point, but I verified this when I was under there pulling the rear driveshaft.
Old Jan 7, 2012 | 10:59 PM
njneer1's Avatar
njneer1
was wondering if someone added one maybe
Old Jan 7, 2012 | 11:03 PM
Sunline Fan
Considering how close to the floor the brake controller was mounted (any farther and it would have been behind the dash), I don't think it did much towing in the past. But I did check when I was under there anyway, since it did have the intake and gauge mods already.
sirkingdra
Oct 2, 2017 12:17 PM
NASCAR Mike
WTB - Ford Trucks & other vehicles
Jan 19, 2014 07:37 PM
lslavick
Dec 26, 2005 10:52 AM
marspec
Aug 10, 2005 11:48 AM
MR.X
Aug 4, 2005 06:44 PM
