Tranny/PTO Question
Old Jan 7, 2012 | 06:13 PM
Sailor182's Avatar
Sailor182
Tranny/PTO Question
Team, my truck is a 5 speed and I have a chelsea PTO unit on it. I have a few leaks around the PTO unit where it attaches to the tranny. I want to remove this and seal it up, any tips on doing this. What type of gear oil goes in this 5 sp.
Old Jan 7, 2012 | 06:41 PM
fordpride's Avatar
fordpride
The ZF5 uses synthetic ATF
Old Jan 7, 2012 | 06:42 PM
fordpride's Avatar
fordpride
For the seal go to ford and get the ford grey rtv
Old Jan 7, 2012 | 09:49 PM
BuckHammer's Avatar
BuckHammer
Like Mike said, the transmission calls for synthetic Mercon ATF.
Old Jan 7, 2012 | 10:05 PM
thewellman's Avatar
thewellman
Are you wanting to remove the PTO for good, or just re-seal it and re-install it. If you pull it for good, obviously you'll need a stock cover plate to take it's place. I'd go to any commercial truck / driveline type shop and they'll have a barrel full of those plates from puttin on new PTOs. If you pull it for good, I could use a back up for mine in case it croaks. Let me know if you want to get rid of it would you? Thanks, Jay
Old Jan 8, 2012 | 06:20 AM
tjbeggs's Avatar
tjbeggs
When you pull it off you may find it one or more gaskets on it. That is not a mistake. The gaskets are used to get the correct gear mesh between the pto and the gear in the trans. Just make sure you put the same thickness gasket back in. There are usually thicker and thinner gaskets too.
Old Jan 8, 2012 | 08:25 AM
dizzyfingers03's Avatar
dizzyfingers03
I was gonna point that out. Said gaskets may be causing the leak.
Old Jan 8, 2012 | 02:34 PM
Sailor182's Avatar
Sailor182
Finally THEWELLMAN comes through, that is what I want to do. I just want to pull it and reseal, I have a few leaks, from what I can see, I see no gasket just rtv of some type oozed out. I want to keep the pto. so I guess the unit gets the mercron from the tranny, cause I need to add some.
Old Jan 8, 2012 | 04:28 PM
tjbeggs's Avatar
tjbeggs
yes the PTO gets lube from the trans. reseal and refill and you should be good to go
Old Jan 8, 2012 | 07:45 PM
dougbrown's Avatar
dougbrown
Did all the zf5 have a pto spot? Would be nice for a dump bed if I change my body?
Old Jan 10, 2012 | 02:18 PM
Splatts's Avatar
Splatts
I got the same deal on mine. Not sure if it has the rtv or not. I just got a little seepage that's all so I will get around to it someday. Let me know if u run into anything odd. Thanks!!!
TheNomad
Oil & Lubrication
Nov 11, 2007 05:02 PM
desert sled
Jan 30, 2006 03:10 PM
rangersvt04
1983 - 2012 Ranger & B-Series
Oct 20, 2005 09:43 PM
FAB150
Oil & Lubrication
May 5, 2005 07:36 AM
Vernon_04_Expy
49
Sep 24, 2004 01:59 PM
