351M...idle problems!!!...HELP!!!!
Old Jan 8, 2012 | 01:16 PM
grclark351's Avatar
grclark351
you can check the vacuum advance by using a Vacula tool and a timing light, you'll see the timing marks move and the engine should gain rpm as vacuum is applied to the can
same for the mechanical advance but w/o the Vacula, timing marks will move as engine rpm increases and should return to where they started out at idle and stay pretty steady
if the dizzy is hooked up to Ported Vacuum there won't be any at idle, it starts pulling somewhere a little above idle, not the greatest for performance but good for emissions & economy. you can T in a vacuum gauge to the dizzy hose an see what it pulls & when, run a long hose around through the drivers window & go for a ride
that's pretty much the first thing to check though, what all is goin on with the timing...
Old Jan 8, 2012 | 01:34 PM
FoMoCo Tech's Avatar
FoMoCo Tech
That's kind of what I thought I had to do to check it. Just wasn't 100% sure. Looks like I'll be bringing my vac pump home tomorrow. haha. Guess I'll crawl under and mark the timing marks today while I'm not doing anyhting. I'll keep ya posted because I'll likely need more help.
HVFDFIREFIGHTER1618
18
Aug 1, 2018 08:56 PM
rivergoast
25
Jun 25, 2017 11:09 PM
rogerlwii
20
Jun 12, 2016 09:09 AM
spltend
Jan 21, 2015 12:21 PM
Inlinetorque
Feb 10, 2011 03:05 AM
