Led dash lights?
Old Jan 7, 2012 | 10:30 AM
Terpfords's Avatar
Terpfords
Led dash lights?
Are they available for our trucks, any recommendations?
Old Jan 7, 2012 | 09:00 PM
Franklin2's Avatar
Franklin2
I bet the dash dimmer will not work correctly with LED's.
Old Jan 7, 2012 | 10:22 PM
x_man586's Avatar
x_man586
Aren't the bulbs in the gauge cluster 194's? If so they make l.e.d. 194's. I don't know about the dimmer though.
Old Jan 8, 2012 | 12:43 AM
TheKirbyMan's Avatar
TheKirbyMan
I converted all my dash lights to red with either colored incandescent 194s or, in the case of less-common bulb types (the bulb above the headlight and wiper switches, factory radio illumination and HVAC controls), I used red taillight tape. They are all plenty bright and IMO there's no real benefit to using LEDs, at least for the gauges. In the case of the gauges, the LEDs might not have the right light spread pattern to properly illuminate the gauge faces. In the HVAC controls it would work, since that uses a 194 as well.
Where LEDs work really well is with the exterior lighting. I have LED taillight bulbs and will eventually swap in some LEDs for the front parking lights. I have LEDs in the side marker lights as well.
If you want LEDs though you can check out some local auto parts stores or go to LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS and see what they have.
Old Jan 8, 2012 | 07:13 AM
Franklin2's Avatar
Franklin2
LED's also give problems in the brake/turn circuits in the rear. The stock flasher will not work with them, and on the later trucks with RABS, the lights will stay on all the time, because they do not present enough load to the circuit.
The taillight problem can be overcome with electronic flashers or load resistors. If you could figure out the proper load needed to make the dash dimmer function correctly, you could probably add a load resistor to it also.
Old Jan 8, 2012 | 06:24 PM
Terpfords's Avatar
Terpfords
Thanks for the replies. My lights have gotten dim and was looking to brighten them up. My truck is blue so do you think blue lights would be an option?
Along the lines of dim lights, I wonder if I don't have to much resistance in my dimming switch? Anyone experience this?
Old Jan 8, 2012 | 07:11 PM
ctubutis's Avatar
ctubutis
I would guess that your blue/green lenses behind the gauges have gotten clouded up like all the other ones in the world.
I installed colored 194s.
You could also clean all the electrical contacts behind the cluster, that might help a little.
RoadkingKai
Jun 3, 2018 12:33 AM
dixokai
Sep 27, 2009 11:08 PM
66f-100
Aug 24, 2008 10:45 AM
nova_mxer
20
May 10, 2007 07:31 AM
chromedaddyo
May 17, 2005 01:10 PM
