Driver side door problem
Old Oct 25, 2002 | 04:15 PM
GB's Avatar
GB
My '95 F150 driver-side door doesn't seem to line up quite right with the door frame. It's a minor problem, really. There is a slight amount of vertical play in the door. When I get out and close the door, I lift the door a bit by the handle so it closes cleanly. If I don't lift, it closes, but I have to close it a bit harder to get it to latch. Like I said, it's not a big problem, but I don't want it to get any worse. Maybe there is away to shim the door just a bit to bring the latch back in line with the frame?
Old Oct 25, 2002 | 04:21 PM
gasman6674's Avatar
gasman6674
I believe the adjustment is at the "bolt" the door latches on. But if you have some play in the door I would look at changing out the hinges.
Gasman
Do you have Gas?
Propane Execeptional Energy
Old Oct 27, 2002 | 08:29 PM
89F150XLT's Avatar
89F150XLT
Sounds like a pin/bushing problem on the hinge might want to try replacing them if the door has up/down movement as described. You should be able to look at them and see that the pin is moving around a tad bit. James
Old Oct 27, 2002 | 10:14 PM
RBrendel's Avatar
RBrendel
i had the same problem. go to a body shop and ask him if they have a tool to adjust your door, it takes 10 seconds fixed mine.
Old Oct 28, 2002 | 01:36 AM
GB's Avatar
GB
Thanks for the advice guys. I'll check with a body shop first, as that might be the easiest way to go. I think this is a fairly common problem. If my memory serves me right, I think my '94 had the same problem, but I didn't do anything about it.
Old Oct 28, 2002 | 06:53 AM
gabany's Avatar
gabany
I have the same issue on my driver's door.
1995 F150XLT XCab 8'Box 4X4
w/ a 302 - 5spd
Old Oct 29, 2002 | 10:38 PM
brett_d's Avatar
brett_d
Old Oct 31, 2002 | 09:09 AM
HDMotorcop's Avatar
HDMotorcop
Seems to be very common.......My old 91 Explorer had the same problem, big time. I ended up shimming the hinges after multiple adgustments were made over the years.
Old Nov 1, 2002 | 04:22 AM
STANG F150's Avatar
STANG F150
I have had the same problem. All you need to do is replace the bushings and pins in the hinges on the door. You can get a pin and bushing kit at your local auto parts store. It should take about a good 30 to 45 minutes to change them and you should not have any more problems with your door, it will close just like it was new, well at least mine did anyway ha ha ha. What ever you do, do not adjust the striker until you replace the pins and bushings first. In most cases the striker doesn't need to be adjusted at all.
