NEW PROBLEM PLEASE HELP
Old Jan 6, 2012 | 12:14 PM
JJJRoberts's Avatar
JJJRoberts
Hi all I use to think I was pretty mechanicly inclined, but I think my truck wants to prove me wrong. I have posted a couple other threads regarding an idle problem and work to try to resolve it. I thought I had fixed it but it started idling how ever it wanted, but now when I shut it off last night I could here gas boiling in the carb. It was 60 degrees out side and my truck was running about 200. I have the EGR plate underneith a 1 inch spacer which my carb sits on top. A little breakdown its a 77 F250 with a 460 backed by a C6 stock except for a 620 CFM carter and an electric fuel pump and a fuel regulator set at about 4PSI. PLEASE any seggestion would be greatly appreciated. I m thinking it may be something to do with the EGR valve or plate.
Thnk you in advance
Old Jan 6, 2012 | 12:35 PM
plumber01's Avatar
plumber01
I wonder if the carb is just getting to hot and messing up the fuel mixture? any way of directing air to the card and running it to see, i really not sure what to say?
Old Jan 6, 2012 | 12:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You said you heard fuel boiling in the carb., are you sure?
Oil from the top end draining back into the pan could be mistaken for that.
Old Jan 6, 2012 | 01:28 PM
JJJRoberts's Avatar
JJJRoberts
Thank you for your responses I am sure it was fuel boiling in the carb I could see a little splashing. I have been doing a little research and other people have had the same problem. One person just put in a spacer and it had solved his problem. Another person was talking about an exhaust valve that is stuck closed. I am wondering I have a plate under the carb that has the EGR connected to it. If the valve was to get stuck open would that heat up the carb. Or I don't know where else to look the fuel line runs near the exhaust manifold as well maybe that contributes to it as well. I have heard of this problem years ago, but have forgotten any details that I might have learned from it. Once again thank you.
Old Jan 6, 2012 | 01:49 PM
plumber01's Avatar
plumber01
Is 4 psi enough, I was thinking between 6-7 for a 460. I could be wrong. But think you may need a little more
Old Jan 6, 2012 | 01:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The original factory installed EGR/carb spacer plates were made from aluminum. Two things happened to them.
1) Heat caused the passages within the plates to melt!
2) Carbon build up was a common occurrence.
The Ford service part replacement EGR plates are cast iron.
Old Jan 6, 2012 | 01:59 PM
fmc400's Avatar
fmc400
MSEE
What material is your spacer made out of? What kind of gasket do you have between the spacer and the carburetor?
Old Jan 6, 2012 | 02:04 PM
co425's Avatar
co425
Carter's need no more than 6psi. Anything more and they flood.
plumber01's Avatar
plumber01
And are you sure the fuel level is correct in the carb (do you have a sight glass that you can see through it)
Old Jan 6, 2012 | 02:07 PM
plumber01's Avatar
plumber01
good to know
Old Jan 6, 2012 | 03:24 PM
JJJRoberts's Avatar
JJJRoberts
I will readjust the PSI to about 5 to 5 and a half. I have the EGR plate and then on top of that I have an aluminum 1 inch spacer. There are regular gaskets inbetween them. If the EGR plate is damage can I remove until I get a new one. I priced them and they are around $100.00. Money is tight right now. Also would that cause the fuel to boil. Also is that to much spacer I bought it set up like that, but it yet to run right.
Old Jan 6, 2012 | 03:33 PM
plumber01's Avatar
plumber01
i hope that does something because if you're running lean, it won't idle right
Old Jan 6, 2012 | 03:36 PM
NumberDummy
Originally Posted by JJJRoberts
I have the EGR plate and then on top of that I have an aluminum 1 inch spacer. There are regular gaskets in between them.
There is one EGR/carb spacer plate, not two. The original factory installed plate was aluminum, before too long, heat caused the little charmer to MELT internally! The Ford service part replacement plate was cast iron.
1977/78 F150/350 & Econoline 460:
D7VZ-9447-C .. Thin Gasket: Spacer Plate to Intake Manifold (Motorcraft CG-497).
D6TZ-9C477-A .. Thick Gasket: Carburetor to Spacer Plate (Motorcraft CG-492).
The thick gasket is equal to...at minimum...8 thin gaskets.
Old Jan 6, 2012 | 04:21 PM
JJJRoberts's Avatar
JJJRoberts
Oh someone put an aftermarket spacer on top of the EGR plate it aluminum
Timehunter
Apr 21, 2018 01:02 PM
Mdc9966
15
Nov 12, 2015 11:51 AM
Art
Jan 4, 2004 03:23 PM
kai123
Mar 19, 2003 01:56 AM
TonyG
13
Dec 10, 2001 07:40 PM
