confused trans code??
Old Jan 5, 2012 | 06:16 PM
IowanStraight6's Avatar
IowanStraight6
Got a truck I'm looking at. The trans code is t, it shows overdrive, drive, and first on the dash. No od button on shifter, its a 93 302 f150. I would have crawled under it but its nothing but sloppy mud.
Old Jan 5, 2012 | 06:28 PM
DRRXR's Avatar
DRRXR
Here you go
Ford Transmission Spotter's Guide .: Articles
Old Jan 5, 2012 | 06:35 PM
White 97 xlt's Avatar
White 97 xlt
That sounds like it might be an AOD, my friend has a 93 150 super cab that has that shift pattern and his is AOD..
Old Jan 5, 2012 | 06:36 PM
DRRXR's Avatar
DRRXR
Your right its a automatic over drive
Old Jan 5, 2012 | 06:50 PM
IowanStraight6
So three speed or basically two speed with overdrive.... Sounds like a real turd
Old Jan 5, 2012 | 07:01 PM
White 97 xlt
3 speed with overdrive.. 4 speeds total!
Ford AOD transmission - Wikipedia, the free encyclopedia
Old Jan 5, 2012 | 07:03 PM
IowanStraight6
Then why does it just have od, d, and one instead of od, 2, 1, with od button
Old Jan 5, 2012 | 07:18 PM
White 97 xlt
The od position will let it go into overdrive. The drive position only lets it shift up to 3 rd gear/direct.. (towing)
First and second gear is used with drive or OD, unless you shift to 2, that starts you off in second and stays in second,(ice and slick conditions) likewise 1 will start off in first gear and stay in first...
Old Jan 5, 2012 | 07:24 PM
IowanStraight6
There's no second though
Old Jan 5, 2012 | 08:13 PM
HrdDrv's Avatar
HrdDrv
Mine has 4-Low, plus revers. = 6
4-hi, plus revers. = 6
Direct, plus revers. = 6
The math comes to................18.
And I use them all!
Old Jan 5, 2012 | 08:32 PM
White 97 xlt
Second is hiding under the 2
Old Jan 5, 2012 | 08:45 PM
IowanStraight6
There's no two on the indicator just a 0d, d,1
Old Jan 5, 2012 | 09:02 PM
White 97 xlt
Ok as far as starting in 2nd, I was mixing a little E4OD in there, sorry.. The trans has a second gear, just no shifter position for it..
Getting old ain't for sissies!!!!!!!!
Old Jan 5, 2012 | 09:17 PM
IowanStraight6
Ahh now its clear thanks
Old Jan 5, 2012 | 09:31 PM
GNR22's Avatar
GNR22
You to grow old, but you never have to grow up!
