Glow plug relay
Old Jan 4, 2012 | 08:21 PM
dmanshane's Avatar
dmanshane
Glow plug relay
How many amp is the factory gpr ??? What's the spec
Old Jan 4, 2012 | 08:26 PM
riverrat41's Avatar
riverrat41
Jim explains it a hell of alot better than I can.Check out below.
https://www.ford-trucks.com/forums/7...pr-system.html
Old Jan 5, 2012 | 02:36 AM
carltonwebb's Avatar
carltonwebb
If you are considering finding another alternative relay that may work better, make sure you
check into the internal wiring configuration of the relay as well as the amps.
If you use the wrong configuration, there is a chance of frying your pcm. For example, a starter relay cannot be used even though it looks similar b/c it grounds through the mounting base. Therefore, if u wire the small power wire to it, the glow plugs will always be on when the key is on.
Old Jan 5, 2012 | 06:13 AM
dmanshane's Avatar
dmanshane
No I was just wondering I'm gonna buy the stancore I was just seeing what the amp difference is in the two I know the stancore is 200 I'm go an have to put a set of glow plugs in she smokes a lot when really cold and when about 35 cranks a little more than it does in the summer
Old Jan 5, 2012 | 11:14 AM
Engalwood's Avatar
Engalwood
Dont throw yr old GPR out, they are worth MONEY at the scrap yard! The contacts are made out of Platium are something like that. Thats why they are soooo expensive... Learned this Yesterday!!!
Ravenous Weasel
Jan 17, 2012 08:30 AM
Kwikkordead
General Diesel Discussion
Feb 15, 2006 09:32 PM
DL
Dec 1, 2005 12:08 PM
mpbpulaski
Oct 17, 2004 10:28 AM
P Eames
Feb 15, 2003 10:44 PM
