alternator wireing question
Old Jan 4, 2012 | 06:58 PM
streetlude95's Avatar
streetlude95
help, the wires from my alternator arent hooked up to anything... (except the little green one, thats hooked up just fine) and i cant take any pics of the dammage. but i traced the harness and it is broken nasty right by the battery. i dont see where they go. apparently the 2 black and one yellow all go togather and go to the battery but i tryed that and it didnt fix the problem.
Old Jan 4, 2012 | 07:04 PM
Ole' gray's Avatar
Ole' gray
any specific vehicle information? engine size/model?
Old Jan 4, 2012 | 07:06 PM
streetlude95
sorry i was in a hurry typing this. its a 90 150 with the 302.
Old Jan 4, 2012 | 07:15 PM
Ole' gray's Avatar
Ole' gray
found this explination, hope its what u were looking for
Wiring for a Ford 302 Alternator | eHow.com
Old Jan 4, 2012 | 07:33 PM
donnor's Avatar
donnor
"You're... FIRED!"
This would be a VERY opportune time to upgrade your fire-prone 2G alternator to a 3G. They are much better, more durable units with arguably better current output for the size and, as alluded to earlier, not so prone to starting underhood fires as are the 2G units.
dn.
Old Jan 4, 2012 | 08:22 PM
F150xlt's Avatar
F150xlt
Here's the schematic for a 88. Can't say the color of the
wires are the same for a 90 but the alternators should be
wired the same.
The three wires you speak of are spliced together to a
16 gauge fusible link. In the schematic it shows
two Black/Orange wires and a Yellow/White wire.
The wires are spliced to a 16 gauge fusible link.
The fusible link is attached to the same lug on
the starter relay where the positive battery cable
bolts to. There should be 4 other fusible links also
bolted to the same lug.
The mess you see is probably the melted fusible link.
You can purchase a new plug with pig tail wires
for the alternator end at most auto part stores such
as NAPA.
The factory plug is a known problem.
Old Jan 5, 2012 | 12:07 AM
streetlude95
^ yup that was it lol
KirstenxMarie
Nov 18, 2022 07:50 PM
Spaulding24
Nov 13, 2018 05:29 AM
88_F0RD
18
Dec 11, 2016 03:34 PM
Raider949
13
Dec 22, 2012 07:31 AM
roller_steve
Oct 17, 2008 10:57 PM
