Sponsored by: Real Truck
Overheating probem
Old Jan 4, 2012 | 02:16 PM
Gene Darco's Avatar
Gene Darco
Overheating probem
I have a 2000 f-350 that overheated 2 months ago I replaced the radiator...it seemed fine for a month then started blowing cold air then would start to overheat and back and forth so I replaced the thermosat.......but when i checked the old one with a cooking theromometer it was fine. not long after that the heater core started leaking so i replaced that..and now its back and forth overheating and blowing cold air....then fine for 1/2 hour..then back and forth again..any ideas truck has 250,000 miles on it
Old Jan 11, 2012 | 01:57 PM
Gene Darco's Avatar
Gene Darco
Ok Ill let you guys know what I find out
Old Jan 11, 2012 | 02:55 PM
Bigpipes 35's Avatar
Bigpipes 35
The only thing I can think of is Head Gasket , But please let us know once you figure it out..
Old Jan 11, 2012 | 05:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is it puking any coolant?
Old Jan 16, 2012 | 05:35 PM
Gene Darco's Avatar
Gene Darco
yea it does but only after ideling for about 20 mins with the resivor cap off the water will be cold and clear if we have been adding then it will raise up and over flow and you can see it change from clear to antifreeze and it also goes from cold to the touch to warm at the same time like a thermostat
Old Jan 16, 2012 | 06:33 PM
Bigpipes 35
Still thinking headgasket...
Old Jan 16, 2012 | 09:34 PM
Gene Darco's Avatar
Gene Darco
I've always thought the oil would be milky if coolant was mixing with it but ill keep it in mind thanks for responding
Old Dec 14, 2013 | 04:45 PM
ChazGrow's Avatar
ChazGrow
First response on your issue from most will be Headgasket.
Drain oil, drain coolant.
What's there?. If not mixed and clear then it's probably not a head gasket. You can reuse if in good condition.
Check and recheck T-stat and all parts collant runs through. Might be a hose line blockage...( water pump fragment, heater core blockage or fragment which can get in the sytem and cause a blockage). Check all passage ways and hoses. Does the lower R-hose colaps under pressure..(engine running or running hot)? It there air in the system?
respond with answers to remove what is not your issue.
Old Dec 14, 2013 | 06:57 PM
RDS250's Avatar
RDS250
That sounds like a head gasket to me. I had the same experience with the wife's Taurus a few years ago when it overheated after the coolant reservoir sprung a leak. It was pushing compression into the cooling system which caused it to push coolant out the coolant reservoir. A blown head gasket will either pull coolant into a cylinder, allow coolant to get in the oil, or allow compression from a cylinder to get into the cooling system. I got lucky and was able to fix it with K&W block sealer. That stuff really works but you must follow the instructions very closely...
Old Dec 14, 2013 | 08:16 PM
One Cylinder's Avatar
One Cylinder
Replace the degas bottle CAP. Lower system pressure = lower boiling point. The cap pressure relief spring may have failed. A new cap is very inexpensive.
Old Dec 14, 2013 | 09:08 PM
ChazGrow's Avatar
ChazGrow
Where is this " degas bottle Cap"?
Old Dec 14, 2013 | 09:10 PM
redford's Avatar
redford
It's that thing you remove to add coolant to your truck.
Old Dec 14, 2013 | 10:05 PM
EXv10's Avatar
EXv10
I think it is the cap also. Head gaskets are rare and they come with a set of telltale signs. You can check your cap at O'Reillys for free. At the same time get a MOTORCRAFT thermo because they have to be just right nowadays with that pre-recirculating system the modular motors have. Do those 2 things and your problems should be over...............keep us posted.
pskj8174
Mar 5, 2016 06:33 PM
Dgreene93
General Automotive Discussion
Feb 26, 2016 09:50 PM
fred_79f250
15
May 19, 2012 12:24 AM
mayhem69
1983 - 2012 Ranger & B-Series
Jan 13, 2009 06:50 PM
No_BS
Dec 2, 2003 08:29 PM
