View Poll Results: Miles at time of ICP failure, and were you running a stock HPOP at the time?
< 100,000 miles
2.50%
100,000 - 149,999 miles
17.50%
150,000 - 199,999 miles
32.50%
200,000 - 249,999 miles
7.50%
250,000 - 299,999 miles
5.00%
300,000 - 399,999 miles
7.50%
> 400,000 miles
0%
Never Failed (please note your miles for this option)
40.00%
Original Stock HPOP at time of failure
25.00%
Reman, Upgraded, or Twin HPOPs at time of failure
0%
Multiple Choice Poll. Voters: 40. You may not vote on this poll
POLL: ICP Sensor Failures
Old Jan 4, 2012 | 10:42 AM
F250_'s Avatar
F250_
Arrow POLL: ICP Sensor Failures
I'm simply surveying here so I can have a more educated guess at proactively changing my ICP sensors on my 7.3's. Tell me when your ICP sensor failed (as best as you can recall), and whether or not you were running a stock HPOP at the time of failure.
Personally, I'm at 211,000 miles on one engine with no failure, and not sure of the mileage on the Ex, but no failure on it. Benjamin's just went out yesterday at about 285,000 miles.
Thanks
Old Jan 4, 2012 | 10:45 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
No failure yet on my ICP, Pete. I don't see a poll.
Old Jan 4, 2012 | 10:50 AM
F250_'s Avatar
F250_
You are too fast, Rick... I had not yet finished it. Check again now.
Old Jan 4, 2012 | 10:58 AM
woodnthings's Avatar
woodnthings
No failure for me either......I am only at 80k though.
Old Jan 4, 2012 | 11:36 AM
Shake-N-Bake's Avatar
Shake-N-Bake
My truck had about 230k miles on the OEM HPOP when I noticed oil in the connector. The sensor was still working but I changed it anyway...
Old Jan 4, 2012 | 12:01 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
My Truck was around 160k, 165 ish when I saw oil in the plug so I just changed it.
Old Jan 4, 2012 | 12:09 PM
kawcrasher's Avatar
kawcrasher
340,000 on mine when I got oil in the plug. Still worked but I changed it due to the oil.
Old Jan 4, 2012 | 12:12 PM
honeydew's Avatar
honeydew
162,000 miles. Just read this thread and went outside to check the plug since I haven't checked it in over a year. Full of oil so I'll order a new sensor tonight.
Old Jan 4, 2012 | 12:55 PM
snakedoc's Avatar
snakedoc
171k stock HPOP and ICP no fail as of now.
Old Jan 4, 2012 | 01:25 PM
F250_'s Avatar
F250_
Related question. Benjamin just put in his new ICP sensor and the truck started up fine, but has a sort of lopey idle at the moment. He did not disconnect the HPOP lines, so I would not expect there to be any air in the system, or can it get air just from changing the sensor and require driving it around a bit to expel the air?
Old Jan 4, 2012 | 02:40 PM
hammer65's Avatar
hammer65
I changed mine around 165,000 because there was oil in the electrical connection. Was still working OK I think.
Old Jan 4, 2012 | 03:09 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
160,000+ never failed.
Old Jan 4, 2012 | 03:29 PM
trekbasso's Avatar
trekbasso
Mine at 203,300. Started idling real rough one morning, had oil in plug, cleaned it and okay. Replaced it anyway. Stock hpop.
No issues after replacing sensor.
Simple but a bit pricey.
Tom.
01 F250.
Old Jan 4, 2012 | 04:18 PM
2000ca250's Avatar
2000ca250
May be a little OT, but what about a sticky IPR or replacing the IPR?
Old Jan 4, 2012 | 04:57 PM
spongecop's Avatar
spongecop
Semper Fi
noob question...is the ICP and IPR the same thing?
