120 miles should use only roughly 9 gallons. I've been doing extensive mileage checking with my truck for a year or so now and that's what I've been getting. Defiantly see if you've got a code or something. I don't know what this paper clip trick is but I just spend the 25 bucks at Oreily's for the Ford Code Reader, it's made by Equus.
what gear ratio are the axles? did you change the speedometer so the speed/mileage is right for your tires? my 95 has the ford dumb idea 3.08 gears,I am running 31 inch tires,and I get 11-12 mpg if I drive sensible,8 if I drive it like I stole it.
well im gonna try and get codes this weekend. my gears are 3.55's and i have no idea about the spedo as i just got this truck . but i used the spedometer app on my phone and im pretty acurate in that department about 2=5 mph off
I just swapped from 31's to 33's/ You need to make sure this has been done. According to my truck, right after I got the tires I went from 13-14 MPG down to 6. Here's the link. to tha article.
